Re: ManualTransmission swap
[Re: 71vert340]
#147952
11/10/08 02:18 AM
11/10/08 02:18 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
It could be the reverse rod on the manual 3 speed tranny currently in the car would work on the OD tranny. I'm just trying to be sure it's a do-able swap so he won't feel I sold him a setup that wouldn't work. Thanks
No, with a 3-speed manual trans, the reverse and 1st rod is shared, as is the 2/3 rod.
It's definitely do-able. There's someone over at slantsix.org adding the same trans to an early A-body- check out the Trans & Rearend section.
[Re: 71vert340]
#147953
11/10/08 03:22 AM
11/10/08 03:22 AM
Posts: 704 USA
rftroy
USA
The shift fork is also different. OD4 only. The pivot point for the fork is farther away from the crank/transmission centerline due to the large diameter 5-1/8" transmission pilot.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
