1989 Shelby Dakota Fuel problems #1479539
08/04/13 05:21 PM
08/04/13 05:21 PM
K
karmakritters Offline OP
K
I have changed the pump, filter, and sock. I think the pump is going out again after less than a month. It is randomly dieing from lack of fuel. I want to just bypass the in tank pump and put one in line. Does any one know which pump would work.
Re: 1989 Shelby Dakota Fuel problems [Re: karmakritters] #1479540
08/04/13 06:02 PM
08/04/13 06:02 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Whats fuel pressure with old and new pumps?
A failing pressure regulator can burn pumps up as well as a restriction or faulty voltage.
These tbi engines are a pia but still pretty simple to fix. Start with codes, then fuel pressure then wiring inspection
Re: 1989 Shelby Dakota Fuel problems [Re: jerseybud] #1479541
08/04/13 06:47 PM
08/04/13 06:47 PM
K
K
I have not checked as I just limped it home. It would crank and run for a minute or two at idle. Once I would press the pedal it would die. It finally cranked up and I was able to drive it home as if nothing was wrong. I am hoping to just bypass the in tank pump with an inline pump. I am planning on a stroker motor next spring so I will need more fuel either way.
