I have a 69 340 block and it's bored out to like 26 or 27 over and going to be tq plate honed to size of the 30 over pistons. I hear you are supposed to fill a block before machining but it can also been done after machining. I kind of would like to fill it but if I could get your opinions on what to do that would be very helpful. Combo as of
now is just going to be a 30 over 340 with about 12:1 cr, mildly ported W2's, M-1
intake manifold with lots of plenum work and port matched, 590 purple shaft cam, iron rockers, stock 3.31 stroke.
