360 won't fire?? #1479463
08/04/13 11:48 AM
08/04/13 11:48 AM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I have a 360 in a 95 dakota ran fine now it wont start at all, it first would kinda fire and run,but as soon as I give it gas it would stumble and then puff out the car like a train. Now nothing. Has spark out of the coil but can't get any out of the dist.
Could the electronic part be bad?
Truck did the stumbling and running ruff yesterday then it stopped and ran fine all last night, then this morning same thing, now nothing.
I'm Lost
Re: 360 won't fire?? [Re: kams] #1479464
08/04/13 12:19 PM
08/04/13 12:19 PM
Andrewh Offline
Andrewh  Offline
did you check if the distributer was rotating?
bad rotor in the distributer or bad cap?
Re: 360 won't fire?? [Re: Andrewh] #1479465
08/04/13 12:21 PM
08/04/13 12:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What are the codes?
Re: 360 won't fire?? [Re: kams] #1479466
08/04/13 01:52 PM
08/04/13 01:52 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
Its a LA 360 with a edelbrock 600 carb. So no codes to read.
Re: 360 won't fire?? [Re: kams] #1479467
08/04/13 04:58 PM
08/04/13 04:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What ignition are you running?
Re: 360 won't fire?? [Re: stumpy] #1479468
08/04/13 07:33 PM
08/04/13 07:33 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
<<<< is useing the crystal ball.. I see a bad "Orange Box"...
I am truckless..
