So I've got my Lokar cable hooked up to the Carter TQ carb...the bracket is attached to the rear drive side corner of the carb base plate. Because this is the 9800 series aftermarkmet carb and has the GM throttle linkage I did have room to mount a bolt in and thread it through the base plate.
Here is what this looks like:
Problem is, the bracket assembly keeps on shifting on me...it simply will not stay put. Hammer the throttle a couple of times and it will shift, basically the bolt that is holding the bracket onto the carb base lets the bracket slip, and the whole assembly shift towards the front of the carb but away from the carb body...sort of at an angle...result is slack in the cable. Now I have that darn thing tightened down as hard as I dare.
Has anyone done something different to mount the Lokar cable? Is there an aftermarket 'old style' manifold based bracket that will accept the cable?
I did see in the Summit catalogue the one piece aluminum carb brackets...they claim to work with Edelbrock carbs as well...seems like a heck of a lot more solid setup...expensive too, but at this point in time I am just looking for a SOLID mount that will not shift, here is an Allstart Performance piece I'm thinking of:
Any ideas / suggestions?
Thanks!
