1968 B body convertible top window? #1479233
08/03/13 11:09 PM
08/03/13 11:09 PM
Mi
sportfury3 Offline OP
Mi
Hi guys, I have a 68 Coronet convertible that I need a new top for. The original top has a plastic window, will a top with a glass window work in the original frame? If not who sells a top with a plastic window? Thanks.
Re: 1968 B body convertible top window? [Re: sportfury3] #1479234
08/04/13 02:08 AM
08/04/13 02:08 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Why wouldnt it work?
My 69 RR rag has a glass back window.
who is that guy?
Re: 1968 B body convertible top window? [Re: sportfury3] #1479235
08/04/13 03:45 AM
08/04/13 03:45 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
My 69 Coronet came with a glass window originally too.
You'll have no troubles putting it back to glass
Electron is a good brand if your undecided as to where to get one from
What color top does your Coronet have?
Re: 1968 B body convertible top window? [Re: sportfury3] #1479236
08/04/13 10:49 AM
08/04/13 10:49 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Your 68 coronet should have had a glass back window. The short of it , you don't need to change the top frame to put a galss back window in it.
Re: 1968 B body convertible top window? [Re: JohnRR] #1479237
08/04/13 11:35 AM
08/04/13 11:35 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
