DUSTER TRANSMISSION TUNNEL #147884
11/09/08 08:38 PM
11/09/08 08:38 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
My duster has a 4 speed trans tunnel and I need one for an automatic. Does anyone know if there is a difference in the trans tunnel for a '70 and up dart, duster , valiant. Valiants and darts are more plentiful around here than dusters.
Re: DUSTER TRANSMISSION TUNNEL [Re: mopars rule] #147885
11/09/08 09:43 PM
11/09/08 09:43 PM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
Any '67-76 A-body floor pan will work.
Just drill the spot welds to remove the 4spd hump from your floor. Use a piece of heavy kraft paper to trace the opening and creat a pattern. Be generous and add at least an inch all the way around. Trace the pattern onto the floor of the donor vehicle and start cutting.
Trim it down to about 3/4" overlap, drill holes centered on the overlap about every 1-1/2" to 2" and use a mig to spotweld the patch panel back in. Don't forget to use seam sealer to finish the job.
Mike
Re: DUSTER TRANSMISSION TUNNEL [Re: dodgedartgt] #147886
11/10/08 12:21 AM
11/10/08 12:21 AM
alabama
mopar addict
mopar addict
alabama
Thanks for the info.
