2006 charger shifter no go! #1478819
08/03/13 11:21 AM
08/03/13 11:21 AM
central illinois
65dodgebob Offline OP
central illinois
Help! Shifter won't move from park.? Wife got in her car this a.m., started engine and no go in to reverse. I haven't got home to look at it yet. Any issues with this shifter , or detent? Thanks!
Re: 2006 charger shifter no go! [Re: 65dodgebob] #1478820
08/03/13 11:27 AM
08/03/13 11:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
did she step on the brake first?
Don't be the exception.
Re: 2006 charger shifter no go! [Re: 65dodgebob] #1478821
08/03/13 11:37 AM
08/03/13 11:37 AM
Arizona
az426john Offline
az426john  Offline
Arizona
It sounds like the "Pink Thingy" issue.
The shifter module for your 300 is probably broken. There is a release tab in case you are stuck in park which allows you to release the shifter from park. If you look to the upper right area of the shifter, there is a small black square tab you can pry open with a small screwdriver or knife. The opening is large enough to stick a screw driver or ink pen into to press down on the release tab. Start the car, press down on the brake, press the release tab, and it should be able to shift from park. If still stuck you will need to remove the chrome trim from around the shifter to reach your handle below the shifter, and move the pink release tab by hand.
Billet Specialties makes a billet Aluminum replacement for the poorly designed plastic POS. It could be as simple as the spring has broken or fallen off also, but I replaced mine with an aluminum one and have not had a problem since. Good luck.
Re: 2006 charger shifter no go! [Re: 65dodgebob] #1478822
08/03/13 12:20 PM
08/03/13 12:20 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
make sure you have brake lights first... no lights = no signal
Re: 2006 charger shifter no go! [Re: ph23vo] #1478823
08/03/13 01:42 PM
08/03/13 01:42 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
The white plastic lever in the front part of the shifter is bad about breaking where the spring hooks to it. You can get a kit through the dealer to fix this. The part number is 68088259ab. I know thats the one that the NAG1(5-speed auto) takes.
Re: 2006 charger shifter no go! [Re: rallye73] #1478824
08/03/13 04:09 PM
08/03/13 04:09 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the little pink plastic lever breaks that holds the spring...Google it or u tube it ..i just did one on a 300..common problem..whole shifter must come out and separated to replace the item, item is 9 dollars...if you pop off the top shifter plate u can stick a screwdriver into the part and just move it to the side to shift and get it home..
Re: 2006 charger shifter no go! [Re: AARCONV] #1478825
08/03/13 05:38 PM
08/03/13 05:38 PM
Dirty South, MS
mopowered Offline
mopowered  Offline
Dirty South, MS
Is definitely the pink thingy broken in the shifter. Both my LX platforms (Magnum + 300C) broke theirs. The Magnum went to the dealership where they fixed it under recall. My 300C wasn't listed in the recall. I use neutral + parking brake as substitute for Park until I get time to pull it and do the cotter pin fix (see lxforums for details). Temp fix for stuck in Park is pull the bezel by lifting with fingernail then use screwdriver (or ice pick or similar) to deflect the cable (coming in from the front) to the left enough for the Park release to engage.
Re: 2006 charger shifter no go! [Re: 65dodgebob] #1478826
08/03/13 06:45 PM
08/03/13 06:45 PM
GEORGIA
barracuda7199 Offline
GEORGIA
here is the permanent fix http://www.custombilletstore.com/Genuine_Billet_Tech_Pink_Thingy_Replacement_p/1028.htm
i have done one of these on a charger getting the shifter out was the hardest part. and it wasn't to difficult just make sure you mark where the shifter cable is set at before you take it loose from the shifter.
Re: 2006 charger shifter no go! [Re: barracuda7199] #1478827
08/04/13 02:26 PM
08/04/13 02:26 PM
central illinois
central illinois
thanks to everyone who responded with help for the shifter problem. ordered new billet part to fix. thanks again moparts!
