Lickity split at the Dave Duell Classic #1478797
08/03/13 10:48 AM
08/03/13 10:48 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
You would think in 90 degree heat you would slow down. My throttle stop bolt is turned in all the way. Still 9.42. Never thought I'd have so much trouble slowing it down.
Doug
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478798
08/03/13 10:50 AM
08/03/13 10:50 AM
tboomer Online work
tboomer  Online Work
Awesome!! Man...That is a great looking car!! And it can put down the numbers!!
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478799
08/03/13 10:54 AM
08/03/13 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
It can be a bit{h to slow a car down... put in a longer
bolt... I lower the launch RPM and the shift points also
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478800
08/03/13 11:17 AM
08/03/13 11:17 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Who cares about the 9.42 on the brakes... I like the .000 light that went with it.
Re: Lickity split at the Dave Duell Classic [Re: dizuster] #1478801
08/03/13 12:01 PM
08/03/13 12:01 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Nice run, 5.99 in the 1/8th. I assume he wants to run a NSS class that has a 9.50 index.
Re: Lickity split at the Dave Duell Classic [Re: cgall] #1478802
08/03/13 07:49 PM
08/03/13 07:49 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Pulled the timing back to 28 total, 9.485. First round won the double breakout by .016 @ 9.475 on the brakes. Took 2 more degrees out to 26. Then it all went wrong. I bumped in to far and went .027 red, car fell off to 9.539, My opponent went 8.761 on a 8.75 index with a .004 light.
Hope I've got all this out of my system for tomorrow.
Doug
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478803
08/03/13 08:11 PM
08/03/13 08:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Don't forget if you bumped in deep you took ET away so you may have it dialed in just right.
Very nice running and looking car.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478804
08/03/13 08:53 PM
08/03/13 08:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That thing is just plain bad ass.............
Re: Lickity split at the Dave Duell Classic [Re: Thumperdart] #1478805
08/03/13 10:45 PM
08/03/13 10:45 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
That car is just plain awesome! Thanks for sharing the build up and the race results with us, Doug!
Randy
Randy
Re: Lickity split at the Dave Duell Classic [Re: pittsburghracer] #1478806
08/04/13 12:00 AM
08/04/13 12:00 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I thought that as well. After watching the video I think it spun. I did roll in, buy not much. I think I missed the tree. I haven't got a good handle on hitting the index all weekend. What worked on the old car isn't phasing this one much. We'll take another stab in the dark tomorrow.
Doug
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478807
08/04/13 08:45 AM
08/04/13 08:45 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Trying to slow it down is a good problem to have Doug
By the way nice slip and good luck Sunday
Re: Lickity split at the Dave Duell Classic [Re: roadhazard] #1478808
08/04/13 09:59 AM
08/04/13 09:59 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I looked at your car Friday Doug. The fit and finish on that car is flawless. A very fast show car.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Lickity split at the Dave Duell Classic [Re: dvw] #1478809
08/04/13 12:58 PM
08/04/13 12:58 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Great update
Re: Lickity split at the Dave Duell Classic [Re: HardcoreB] #1478810
08/04/13 02:44 PM
08/04/13 02:44 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Doug
I seen your car at Indy best looking 64 I've ever seen, and it runs great to
Brian
