Help with fuel pump fitting specs... #147878
11/09/08 08:06 PM
11/09/08 08:06 PM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
I'm looking at mechanical fuel pumps on summitracing.com. The GM4539 says that this fuel pump - gm4539
- has "stock" inlet and outlet sizes. What were stock for 69-71 440s? I'd like a threaded inlet and outlet rather than hose connections, but what size? 1/4 pipe thread? 5/16 pipe thread? 3/8 pipe thread? or are they 5/16 inverted flare fittings?
As always, thanks in advance,
Marq
Re: Help with fuel pump fitting specs... [Re: MoparMarq] #147879
11/09/08 08:24 PM
11/09/08 08:24 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Marq,
Cannot say for certain, but that looks like the same
unit I bought for my 340. The threads on mine
were 1/4" NPT or NPTF.
Thats all the help I can give.
Re: Help with fuel pump fitting specs... [Re: Dart 340] #147880
11/09/08 08:27 PM
11/09/08 08:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This was covered a few weeks back, the pump you get won't look anything like the picture on the summit site...
Re: Help with fuel pump fitting specs... [Re: 1_WILD_RT] #147881
11/09/08 10:04 PM
11/09/08 10:04 PM
Vancouver, WA
Vancouver, WA
Thanks. I just called Napa with that part number, and their book says the inlet is a hose barb, outlet threaded, with a stamped ring, rather than screwed shut, case. Guess I'll keep looking...
