318 Exhaust Manifold Outlet Size. #1478700
08/02/13 11:48 PM
08/02/13 11:48 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Have an '84 LA 318 in a Ram in need of dual exhaust. It has 2" pipe off the manifold now and was wondering what the outlet size is at the manifold?
Hopefully, bigger than 2"
Thanks.
Mo' Farts
Moderated by "tbagger".
Re: 318 Exhaust Manifold Outlet Size. [Re: Grizzly] #1478701
08/03/13 12:14 AM
08/03/13 12:14 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Just measured a 73 Challenger manifold. ID of the outlet is only 1 3/4".
Re: 318 Exhaust Manifold Outlet Size. [Re: burdar] #1478702
08/03/13 03:45 AM
08/03/13 03:45 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If the pipe is 2" the outlet will be 2"... The 360 manifolds had 2 1/4 pipes and outlets..
I am truckless..
Re: 318 Exhaust Manifold Outlet Size. [Re: 340SHORTY] #1478703
08/03/13 09:55 AM
08/03/13 09:55 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Tell that to the manifold I just measured before posting. I was shocked it was only 1 3/4". Maybe a truck manifold is larger? My measurement was ID. Most exhaust pipes are measured OD.
Re: 318 Exhaust Manifold Outlet Size. [Re: burdar] #1478704
08/03/13 11:45 AM
08/03/13 11:45 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
I suppose, but was hoping to hear 2 1/4 like the 360 mentioned.
Well, and I searched it out a bit and can't find anything except for Magnum engines. Must be a few variations of 318 manifolds?
So, would the stock pipes on a '73 318 be 1 3/4" too? I have a '74 'Cuda that's all original but I can't get at it to measure.
Thanks for checking Burdar.
Mo' Farts
Re: 318 Exhaust Manifold Outlet Size. [Re: Grizzly] #1478705
08/03/13 03:47 PM
08/03/13 03:47 PM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
I don't know what the stock size was off the manifold. It could have been 2".
Re: 318 Exhaust Manifold Outlet Size. [Re: Grizzly] #1478706
08/03/13 04:21 PM
08/03/13 04:21 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I made an exhaust system for my '86 Ram W150 when I was working at an exhaust shop. 2" flared to connect the the mainfold, then I welded 2-1/4" onto the 2" right after the flange area. The pipes basically came down a bit farther before bending towards the back so there was plenty of clearance around the oil filter. Both sides came back past the transfer case, then the drivers side crossed over to the passenger side and ran both 2-1/4" pipes into a dual inlet single 3" outlet Imco chambered muffler (I think installed backwards), with a 3" outlet that went over the rear axle and exited out the passenger side at about a 45 degree angle right before the end of the truck. The end of the pipe was cut parallel the the bed side so it had the angled looking exit. It sounded pretty good on a mild 318.
