Small block crank trigger dist. #1478551
08/02/13 08:22 PM
08/02/13 08:22 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
I have a billet dist in my w-8 that has no pick up in it and a crab style cap. It has no numbers on it. Called msd they say they dont make one. No go from mallory. Just curious if anybody knows who makes one or where to get one.
One day I will have something cool here.
Re: Small block crank trigger dist. [Re: sdaurity] #1478552
08/02/13 10:18 PM
08/02/13 10:18 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Were the innards just pulled from it ?
Homemade ? I don't recall ever seeing one for a MoPar small block.
Front drive , sure. Regular dizzy.....nope.
Re: Small block crank trigger dist. [Re: tubtar] #1478553
08/03/13 12:32 AM
08/03/13 12:32 AM
Out West
408strokerdart Offline
Out West
MSD made one when they first started making crank triggers. They didn't have the crab cap though. I just sold one a few months ago when I bought the front drive distributor.
Re: Small block crank trigger dist. [Re: 408strokerdart] #1478554
08/03/13 11:03 AM
08/03/13 11:03 AM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
I got one cwith a crab cap. Maybe the cap/ rotor was same as a small chevy and somebody switched it over. But you answered my question the use to make them. In that case anybody got one? Thanks for the info.
Re: Small block crank trigger dist. [Re: sdaurity] #1478555
08/03/13 12:31 PM
08/03/13 12:31 PM
Out West
Out West
I'm sure you are right....someone changed out the base/cap from a Chevy unit to make what you have. I was going to do the same thing before I went front drive.
Re: Small block crank trigger dist. [Re: 408strokerdart] #1478556
08/03/13 10:36 PM
08/03/13 10:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
must have been a long time ago I spoke with them in 2006 when I was putting my last motor together and the had nothing. I ended up just gutting a plain old dizzy.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Small block crank trigger dist. [Re: dusturbd340W5] #1478557
08/04/13 08:15 AM
08/04/13 08:15 AM
Finland
mafo Offline
mafo  Offline
Finland
I have one like that ,brand new in the box, from Nickens garage sale a few years back, I ll get the model numbers for you later
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Small block crank trigger dist. [Re: mafo] #1478558
08/04/13 10:10 AM
08/04/13 10:10 AM
Finland
mafo Offline
mafo  Offline
Finland
Crab cap and all...
Re: Small block crank trigger dist. [Re: mafo] #1478559
08/04/13 01:54 PM
08/04/13 01:54 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Awesome. Thanks for the part#
Re: Small block crank trigger dist. [Re: sdaurity] #1478560
08/04/13 02:28 PM
08/04/13 02:28 PM
Out West
Out West
That is a vintage part. I didn't know they ever came with a crab cap.
Re: Small block crank trigger dist. [Re: 408strokerdart] #1478561
08/04/13 03:31 PM
08/04/13 03:31 PM
Finland
mafo Offline
mafo  Offline
Finland
I collect vintage sb race parts...
I checked for parts numbers, no paperwork in the box and nothing on the parts
Re: Small block crank trigger dist. [Re: mafo] #1478562
08/04/13 04:21 PM
08/04/13 04:21 PM
North Cackilacky
sdaurity Offline OP
sdaurity  Offline OP
North Cackilacky
Mine actually has h.e.i ends on the cap.
