Stamped Wheel ID #147840
11/09/08 06:31 PM
11/09/08 06:31 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
#3580164 15 x 6.5 What is the part number for ?
With stem at 12 noon, to the left is 18, both
numerials together. To the right of the stem
the numerial 8 I assume 1968 ? K2 in the center
(kelsey)and it has the H in the bolt circle.
Logan426
Re: Stamped Wheel ID [Re: MLR426] #147841
11/10/08 02:15 PM
11/10/08 02:15 PM
ILL
MLR426 Offline OP
MLR426  Offline OP
ILL
Re: Stamped Wheel ID [Re: MLR426] #147842
11/10/08 10:57 PM
11/10/08 10:57 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Logan426
a 3580*** PN is for a 70's vehicle. The 18 means the 18th of the month and the 8 means August so the wheel was stamped August 18th. What we don't know yet is the year. Look under the K2 for another number. That will be the year.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Stamped Wheel ID [Re: MLR426] #147843
11/11/08 09:23 PM
11/11/08 09:23 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Logan426
Its not an big $$ H wheel, its a $10 wheel
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
