best place for replacement a/c condensor for 69 b-body? #1478367
08/02/13 12:50 PM
08/02/13 12:50 PM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
hi
not looking for original correct,
just a new bolt in replacement
does anyone have any recommendations?
thanks
Re: best place for replacement a/c condensor for 69 b-body? [Re: TONY_DAGOSTINO] #1478368
08/02/13 01:49 PM
08/02/13 01:49 PM
PA
BTTG Offline
BTTG  Offline
PA
year one has them for $230... get a 20-30% off code and price is reasonable for a correct looking one (know you said correct isn't needed)... guessing you probably won't find locally?
https://www.yearone.com/Product/1966-74-a-b-e-body/ai3307
Re: best place for replacement a/c condensor for 69 b-body? [Re: TONY_DAGOSTINO] #1478369
08/03/13 01:02 AM
08/03/13 01:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Vintage Air?
Re: best place for replacement a/c condensor for 69 b-body? [Re: 451Mopar] #1478370
08/03/13 07:58 AM
08/03/13 07:58 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
You could also try americancondenser.com. I've got two of their condensers on my cars now.
Re: best place for replacement a/c condensor for 69 b-body? [Re: Mopar73340] #1478371
08/03/13 10:30 AM
08/03/13 10:30 AM
IN
ahy Offline
ahy  Offline
IN
Classic Auto Air in Florida should have a high efficiency aluminum with factory line routing. I used one on an E. Bouchillon will have a high efficiency also but I don't think line routing will be as original. The Rock Auto posted above sounds pretty good also.
Re: best place for replacement a/c condensor for 69 b-body? [Re: TONY_DAGOSTINO] #1478372
08/04/13 09:17 AM
08/04/13 09:17 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Efficiency over originality was my high priority.
Bought a parallel flow condenser and added a pusher fan. What a difference!!!
Go parallel!
Re: best place for replacement a/c condensor for 69 b-body? [Re: Commando1] #1478373
08/04/13 10:24 AM
08/04/13 10:24 AM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
What I didn't mention above is the american condenser units I have fit the stock location mounting and lines and are dual pass which makes them more efficient than the stock units.
Re: best place for replacement a/c condensor for 69 b-body? [Re: TONY_DAGOSTINO] #1478374
08/04/13 03:35 PM
08/04/13 03:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bolted in a 1969 Charger R/T like it was made for it
ZERO complaints from me
http://www.ebay.com/itm/1966-1967-1968-1...3f3&vxp=mtr
