Silicon brake fluid.
#1478262
08/02/13 11:13 AM
08/02/13 11:13 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
How many have used it? Does it give a different pedal feel? Since I did all new everything on the Bee, and it will sit all winter, I filled it up with silicon fluid. The pedal feel doesn't make me happy. Is there a different 'feel' to it, or do I need to keep bleeding? I bench bled the master cylinder, and I have bled each line ttwice starting from the right rear. All connections are tight, no leaks, and no more bubbles! I will most likely hit them again when I go through the mental checklist before I drive it out of the garage. Just looking for your thoughts. Richard E., you out there?!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Silicon brake fluid.
[Re: BTTG]
#1478264
08/02/13 12:04 PM
08/02/13 12:04 PM
Posts: 1,385 Az
69hemibeep
Az
I put it in my new system and can't feel any difference from the old
1969 Hemi Roadrunner 2nd owner
[Re: OhioMopar]
#1478265
08/02/13 12:08 PM
08/02/13 12:08 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
keep bleeding, no brake fluid is compressable, only the air in it is. You can't feel any difference between Dot 3 and Dot 5
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1478266
08/02/13 01:33 PM
08/02/13 01:33 PM
OhioMopar
Mt.Gilead, Ohio
Thanks guys. I'll keep bleeding. I didn't do any warming of anything. Just poured it in.
