Tail / brake lights out #1478099
08/01/13 09:38 PM
08/01/13 09:38 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
My tail lights and brake lights aren't working. I was sure that it was the fuse, and when I checked it - sure enough - it was out. But when I replaced it, the lights STILL weren't working. The bulb filaments all look good and the license plate light IS working, so I'm not sure what to check next. It's probably simple, but I'm stumped. Any suggestions?
Thanks in advance for any help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Tail / brake lights out [Re: 1968RR] #1478100
08/01/13 09:46 PM
08/01/13 09:46 PM
1968RR Offline OP
1968RR  Offline OP
Also, turn signals and side marker lights ARE working, just no tail lights or brake lights.
Re: Tail / brake lights out [Re: 1968RR] #1478101
08/01/13 11:07 PM
08/01/13 11:07 PM
(1) tail (running) lights/lic plate light/side marker lights are on the same single hot wire originating from the headlight switch so since the taillights work you have power to the rear of the car. At the T back there find the open from it to the bulbs/sockets, see that the bulb(s) are making good contact at the base contact for the small filaments. check that the bulb case/sockets have continuity to ground. (2) Turn signals and brake lights are on the same 2 wires at the connector behind the drivers side kick panel so since the TS work then the open is upstream from there (TS switch/its' harness/brake light switch/brake light fuse). Unplug the dangling TS/brake connector under the column & see if the white wire in the body half of the connector has fire when the brake pedal is depressed. If good there then with the TS stalk in neutral see on the column half of the connector with your VOM see if there is continuity between the white wire and the 2 brake light wires (there should be). www.mymopar.com has the colors for you. One of these tests will tell you something
Re: Tail / brake lights out [Re: RapidRobert] #1478102
08/01/13 11:32 PM
08/01/13 11:32 PM
1968RR Offline OP
1968RR  Offline OP
I rechecked, and it appears that the brake lights DO work (my wife wasn't pressing down on the brakes hard enough the first time I checked). Also, the first time I tested, the side marker lamps were working, but now they aren't (making me think I've got a loose wire somewhere). So now everything works except for my tail lights and (sometimes) my side marker lights. I'll try the tests you recommended and see if I can find anything. Thanks.
Re: Tail / brake lights out [Re: 1968RR] #1478103
08/02/13 07:13 PM
08/02/13 07:13 PM
1968RR Offline OP
1968RR  Offline OP
All lights are now working except for the tail lights. I've checked the bulbs and they're good. Where should I check next for a bad connection?
Re: Tail / brake lights out [Re: 1968RR] #1478104
08/02/13 07:27 PM
08/02/13 07:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Recheck the fuses.
Re: Tail / brake lights out [Re: stumpy] #1478105
08/02/13 07:31 PM
08/02/13 07:31 PM
1968RR Offline OP
1968RR  Offline OP
Fuses are all good. Does the tail light fuse also affect the turn signal and license plate lights?
Re: Tail / brake lights out [Re: 1968RR] #1478106
08/02/13 07:44 PM
08/02/13 07:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Plate light yes. Turn signals no.
Re: Tail / brake lights out [Re: stumpy] #1478107
08/02/13 08:34 PM
08/02/13 08:34 PM
1968RR Offline OP
1968RR  Offline OP
Plate light is working. So where do they tail lights and plate light branch off of the same hot wire? Anyone happen to have a wiring schematic?
Re: Tail / brake lights out [Re: 1968RR] #1478108
08/02/13 08:42 PM
08/02/13 08:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
diagrams can be found on mymopar.com
Re: Tail / brake lights out [Re: stumpy] #1478109
08/02/13 10:33 PM
08/02/13 10:33 PM
1968RR Offline OP
1968RR  Offline OP
Thanks, Stumpy.
Re: Tail / brake lights out [Re: 1968RR] #1478110
08/02/13 11:22 PM
08/02/13 11:22 PM
They are both at the rear of the vehicle so the T/branch will be located at/near the loom where it goes from the DR tail light area across to the PASS tail light area. The plate light wire drops straight down halfway across
