clutch adjustment on 84 d 100 4 speed #1477490
08/01/13 10:09 AM
08/01/13 10:09 AM
ontario canada kingston
aspenrt360 Offline OP
hey guy's is there any adjustment on one of these? i am thinking about picking one up but the guy saya the clutch is really soft and i dont want to have to tow it if i can get away with nursing it back home. thanks
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: clutch adjustment on 84 d 100 4 speed [Re: aspenrt360] #1477491
08/01/13 01:56 PM
08/01/13 01:56 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
It's a hydraulic clutch so there's no adjustment.
Re: clutch adjustment on 84 d 100 4 speed [Re: John_Kunkel] #1477492
08/01/13 02:40 PM
08/01/13 02:40 PM
thanks for the response! I thought it might be but I have never had a truck that was a stick.
Re: clutch adjustment on 84 d 100 4 speed [Re: John_Kunkel] #1477493
08/01/13 07:23 PM
08/01/13 07:23 PM
scratchnfotraction Offline
I thought the hydro clutch system came in 86 with a hole in the firewall and the 4 holes to mount the clutch MC bracket to the colum stand under the dash.
85 last yr for mech linkage and stepside bed.
the very reason I am swaping my 85 cab for 86-93 cab.
but then again,I have been wrong before.
Re: clutch adjustment on 84 d 100 4 speed [Re: scratchnfotraction] #1477494
08/01/13 08:15 PM
08/01/13 08:15 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
My 84 had mechanical linkage.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: clutch adjustment on 84 d 100 4 speed [Re: aspenrt360] #1477495
08/01/13 09:55 PM
08/01/13 09:55 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
84 should have mechanical linkage, adjust for 1 inch freeplay at the pedal. Nut to turn is near the bellhousing boot under the truck. Service parts were still available from Mopar perf as a E/B body clutch parts kit, but I think that was disco'ed.
The return spring pulling the arm back from away so the throwout bearing had some space was notorious for breaking on these as well so check for it.
As for hydraulics, pretty sure 1st year overall from factory was 87s with a 6 cylinder, then they all got it in 88. (trucks)
Re: clutch adjustment on 84 d 100 4 speed [Re: jerseybud] #1477496
08/02/13 11:36 AM
08/02/13 11:36 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
my '85 was mechanical
1981 Dodge D150 360 auto
Re: clutch adjustment on 84 d 100 4 speed [Re: basketcase] #1477497
08/02/13 09:18 PM
08/02/13 09:18 PM
ok then so there is a chance I may be able to adjust some life into it to linp it home! thanks guy's
Re: clutch adjustment on 84 d 100 4 speed [Re: aspenrt360] #1477498
08/03/13 07:37 PM
08/03/13 07:37 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
This is the clutch fork adjustment rod, with the nut you rotate to adjust at the bottom right. Bring your favorite penetrating oil along, though, as the nut is often frozen to the rod:
This is for B-vans, but D/W will be very similar:
