Re: 727 doesn't like to shift into 3rrrrrrrrrd
[Re: viperblue72]
#1477446
08/01/13 10:28 AM
08/01/13 10:28 AM
Posts: 1,443 Maryland
Dads426
Maryland
Same thing happened to us in our 340 car. If you are using a late 727 case, Chrysler didn't machine the groove in the front clutch drum (IIRC) correctly and the seal starts to leak where the up shift occurs later and later. An air test with the valve body removed will confirm this. If so, the trans has to come out. Replacing the seal will fix it for a while.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Coronet-R/T-Rag]
#1477447
08/01/13 02:17 PM
08/01/13 02:17 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Sounds like worn governor sealing rings....they can be replaced without pulling the trans.
#1477449
08/03/13 04:56 PM
08/03/13 04:56 PM
John_Kunkel
Rio Linda, CA
Your trouble isn't inside the pan; lift-throttled shifts to 3rd and uncommanded downshifts to 2nd are classic governor sealing problems.
[Re: John_Kunkel]
#1477450
08/04/13 09:14 AM
08/04/13 09:14 AM
Posts: 629 Michigan
dart1962_440
Is it easy to change the seals? My wagon seems to be doing the same thing. Where are the seals available from?
