Brake booster change #1477141
07/31/13 04:35 PM
07/31/13 04:35 PM
New Kent, Virginia
matts69Dart Offline OP
New Kent, Virginia
I am in the process of changing the power brake booster on my 87 D150 to the smaller 3/4 booster. I have the aluminum m/c, but the booster for the cast iron m/c is cheaper and more readily available. Can I use that booster with my aluminum m/c? What is the difference? Thanks in advance. Matt
Re: Brake booster change [Re: matts69Dart] #1477142
07/31/13 06:55 PM
07/31/13 06:55 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Doesnt the cast MC use 4 mounting bolts/studs where the alom MC uses 2 bolts/studs??
I am truckless..
Re: Brake booster change [Re: 340SHORTY] #1477143
07/31/13 07:34 PM
07/31/13 07:34 PM
New Kent, Virginia
New Kent, Virginia
They both use two bolt mounting
Re: Brake booster change [Re: matts69Dart] #1477144
07/31/13 07:38 PM
07/31/13 07:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Shouldn't be an issue that I can think of
Re: Brake booster change [Re: 76dodgeboy] #1477145
07/31/13 09:50 PM
07/31/13 09:50 PM
New Kent, Virginia
New Kent, Virginia
They are two different part numbers, so I was wondering if there is a difference in the plungers.
Re: Brake booster change [Re: matts69Dart] #1477146
07/31/13 10:07 PM
07/31/13 10:07 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I doubt they made 3 different rod lengths. I've only heard on power and manual rods
Re: Brake booster change [Re: 76dodgeboy] #1477147
08/01/13 12:00 AM
08/01/13 12:00 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
You may find that the bolt spacing is different for the cast iron booster.
IIRC the cast is going to be spread farther apart than the aluminum.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Brake booster change [Re: hp383] #1477148
08/07/13 09:29 PM
08/07/13 09:29 PM
New Kent, Virginia
New Kent, Virginia
A little FYI on the booster. I had to drill out the mounting holes on the aluminum m/c to 3/8s. The rod between the m/c and the booster is also approximately 1/4 longer than the original. I made a spacer out of 1/4 inch aluminum and everything works great. Noe I have valve cover clearance. Matt
Re: Brake booster change [Re: matts69Dart] #1477149
08/08/13 02:23 AM
08/08/13 02:23 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Did you install a 440 into the truck?
If you have could you maybe post a picture of the PCV valve area.
I'm trying to figure out why mine won't fit with the small booster and factory valve covers.
Re: Brake booster change [Re: hp383] #1477150
08/08/13 03:14 AM
08/08/13 03:14 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It fits. Jamie arent yours
Re: Brake booster change [Re: 76dodgeboy] #1477151
08/08/13 05:50 PM
08/08/13 05:50 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
Ummm What?
