Re: Brake booster change
[Re: 76dodgeboy]
#1477147
08/01/13 12:00 AM
08/01/13 12:00 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
You may find that the bolt spacing is different for the cast iron booster.
IIRC the cast is going to be spread farther apart than the aluminum.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: matts69Dart]
#1477149
08/08/13 02:23 AM
08/08/13 02:23 AM
hp383
State of Confusion
Did you install a 440 into the truck?
If you have could you maybe post a picture of the PCV valve area.
I'm trying to figure out why mine won't fit with the small booster and factory valve covers.
