1979 Dodge Magnum Front End Work #1477098
07/31/13 03:39 PM
07/31/13 03:39 PM
Cascade, CO
reknapp52 Offline OP
Cascade, CO
I will be swapping out almost all front end components on a 1979 Dodge Magnum for a customer, including upper and lower control arms, sway bar, shocks, steering centerlink. Looking for a ballpark number on how many hours it will take--I know there will be some minor fitment issues, the new parts are aftermarket. Just looking for a realistic estimate for the R&R work. Thanks.
Re: 1979 Dodge Magnum Front End Work [Re: reknapp52] #1477099
07/31/13 04:36 PM
07/31/13 04:36 PM
Franklin Square, NY
CUDAAR Offline
CUDAAR  Offline
Franklin Square, NY
According to my COLLISION database, it gives you 2.7 hours to overhaul each side or 5.2 hours for both.
Centerlink & stabilizer bar adds another 1.5 hours.
Add .2 hours to remove wheels.
Does NOT include wheel alignment, ride height adjustment,caliper replacement or adding for rusted parts removal.
I can email a print out to you if needed.
-Lou
Re: 1979 Dodge Magnum Front End Work [Re: CUDAAR] #1477100
08/01/13 12:10 AM
08/01/13 12:10 AM
Cascade, CO
Cascade, CO
Thanks Lou, your info will get me close enough--I am also installing Wilwood brakes.
