Re: 383 starter size problem
[Re: MOPARMIKE69]
#1476923
08/07/13 01:45 PM
08/07/13 01:45 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
OMG!!!!!! What an idiot! Well that settles that. Thanks for your help guys. Even with it in backwards it still has to be the wrong size. I know what I will be buying at the Nats!
No it shouldn't be the wrong size if it's a 130 tooth wheel and the original 513 bell. The pilot hole will not be blocked with the wheel in correctly. If you feel like you have to buy a new flywheel get a billet wheel.
[Re: superbeedave]
#1476926
08/15/13 02:05 PM
08/15/13 02:05 PM
Posts: 1,565 tennessee
pushbutton
tennessee
MoparMike69, Did you ever get this issue taken care of? Just curious!
[Re: pushbutton]
#1476927
08/16/13 09:00 AM
08/16/13 09:00 AM
Posts: 2,634 Nashville, TN
MOPARMIKE69
Nashville, TN
Talked to Wayne Brewer at the Nats. He gave me the diameter measurements of the correct flywheel. I compared my inspection cover with one of his 10.5 ones and they match, and my bell is alum also. So this weekend I will be pulling the flywheel and then I will also be able to confirm the bell housing. Oh and just for general info he said there isn't any way to put the flywheel in backwards and bolt up the clutch. I hope to be able to move on after this week end! I will update.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1476928
08/16/13 10:39 AM
08/16/13 10:39 AM
JohnRR
U.S.S.A.
If that is the case them what may have happened is that someone swapped the flywheel ring gear and put it on wrong ??? I just had one flipped because of some ground teeth , heat it up and it falls off , heat it up and slip it on ???
[Re: bdusted440]
#1476930
08/17/13 12:24 PM
08/17/13 12:24 PM
Posts: 2,177 ill
dennismopar73
ill
(quote),Talked to Wayne Brewer at the Nats. He gave me the diameter measurements of the correct flywheel. I compared my inspection cover with one of his 10.5 ones and they match, and my bell is alum also. So this weekend I will be pulling the flywheel and then I will also be able to confirm the bell housing. Oh and just for general info he said there isn't any way to put the flywheel in backwards and bolt up the clutch.(quote), Mr Brewer needs to call me,!! Because I have seen flywheels put in backwards,and clutch bolted up!! as well, so yes it can be done ,is done, !! still appears you have the wrong flywheel as well!
[Re: MOPARMIKE69]
#1476932
08/17/13 06:35 PM
08/17/13 06:35 PM
pushbutton
tennessee
Ok. pulled it all. Bell housing # 2892513. Flywheel 13 1/4 diameter. 130 tooth. ??????
Was the flywheel on backward?
[Re: pushbutton]
#1476933
08/17/13 09:19 PM
08/17/13 09:19 PM
Posts: 508 Cincinnati, Ohio
superbeedave
Cincinnati, Ohio
Bueller! Bueller! We're waiting! Gotta be something wrong.
[Re: MOPARMIKE69]
#1476935
08/17/13 10:58 PM
08/17/13 10:58 PM
pushbutton
tennessee
No
Keep us posted.
[Re: MOPARMIKE69]
#1476938
08/19/13 10:07 AM
08/19/13 10:07 AM
JohnRR
U.S.S.A.
Are you asking if that one is a 130 tooth or you have confirmed it is by counting the teeth now that it is out ?
I have looked at pictures of original flywheels and it's hard to tell if that ring gear is in the right place or not. I have a bunch of flywheels at home but I keep forgetting to drag one out, I'll look tonight if no one comes up with a picture and measurement.
[Re: dennismopar73]
#1476941
08/19/13 12:09 PM
08/19/13 12:09 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Show me a picture of a mopar V8 flywheel bolted up to a crank backwards with all 6 bolts? Can't be done.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
