1970 b-body power disc brake booster/master cylinder ?? #147676
11/09/08 09:07 AM
11/09/08 09:07 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
What determines which cars got the master cylinders with the lines toward the engine vs. toward the inner fender. Always heard it was a HEMI vs. big-block thing, but that doesn't seem to be the case. Early/late or plant thing; with b-bodies built at Lynch Rd., St. Louis, and LA? Is there anything on the b'cast sheet that would point towards one or the other?
I have a (February '70) '70 LA "E" built GTX with power disc brakes -
-- it has the bendix booster with master cylinder with the brake lines to the inner fender.
There is a (October '69) '70 St. Louis "G" built Charger SE with power disc brakes on Ebay -
-- it has the same set up
Re: 1970 b-body power disc brake booster/master cylinder ?? [Re: 6bblgt] #147677
11/13/08 05:48 PM
11/13/08 05:48 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Stumped the "MOPARTS" crowd? Say it isn't so!
Here's a pic of my GTX, lines look a little "goofy" but original with no "kinks" from turning them around.
I went through all the '70 b-bodies on the 'bay;
most of the power disc brake lines are toward the inner fender but there are a bunch toward the engine?
Re: 1970 b-body power disc brake booster/master cylinder ?? [Re: 6bblgt] #147678
11/13/08 06:00 PM
11/13/08 06:00 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
My 70 R/T has them facing the fender, but do not look like the last one pictured. The lines take a hard bend, but are very symmetrical and neat. Perhaps that is because the master cylinder is wrong on the green car.
MB
Re: 1970 b-body power disc brake booster/master cylinder ?? [Re: HPMike] #147679
11/13/08 07:08 PM
11/13/08 07:08 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
thanks Mike, What plant & SPD is your black car?
I know my M/C is incorrect, there was a NOS unit on the 'bay with the lines toward the engine listed as '70 b-body w/power disc brakes. Evidently they came both ways, WHY/WHEN/WHERE???
Re: 1970 b-body power disc brake booster/master cylinde [Re: 6bblgt] #147680
11/13/08 07:09 PM
11/13/08 07:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I never saw this , the ones toward the inner fender were NORMALLY found on HEMI cars , but I guess a few could have gotten thru the other way if the toward the engine units weren't in stock at build time ???
BUT looking at that particular master and knowing what I know , that is NOT a correct B body master cylinder for 1970 , that looks like the later E/B body and everything else unit , plus it should be painted BLACK , that's been replaced somewhere along the line
Just looked at the pic again , it APPEARS that SOMEONE also bent those lines to meet up with that master cylinder .
Re: 1970 b-body power disc brake booster/master cylinder ?? [Re: 6bblgt] #147681
11/13/08 07:16 PM
11/13/08 07:16 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
My R/T has a SPD of 7/14/70 and it is a St. Louis car. I never checked, but it must be one of the last 6 pk. R/T's produced.
Re: 1970 b-body power disc brake booster/master cylinde [Re: JohnRR] #147682
11/13/08 07:28 PM
11/13/08 07:28 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Disc brake master cylinders for '68-'70 B bodies have the lines toward the engine except for hemis. The hemi and non hemi application disc brake master cylinders are basically the same 1-1/8" bore parts internally, so why they changed to the line toward the engine style in '68 I can't even speculate (in '67 all B body master cylinders had lines toward the fender).
For the last over 20 years, the only replacement 1-1/8" cylinder available new for these applications was the line toward the fender style, which probably explains why you see that part on so many cars. Many would rather rebend brake lines than try to find the lines toward engine style cylinder.
If you check the Chrysler part numbers for B body master disc brake numbers you will find the part numbers for non-hemi are for the line toward engine style.
The cylinder shown in that picture on the green car is an aftermarket '71-'75 disc brake cylinder and the brake lines are not bent in an OE manner.
Re: 1970 b-body power disc brake booster/master cylinde [Re: Mastershake340] #147683
11/13/08 11:27 PM
11/13/08 11:27 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
I would agree that Mastershake340 is correct-I have never seen a true original car any other way.
Re: 1970 b-body power disc brake booster/master cylinde [Re: Mastershake340] #147684
11/14/08 01:30 AM
11/14/08 01:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 1970 b-body power disc brake booster/master cylinde [Re: JohnRR] #147685
11/14/08 09:48 AM
11/14/08 09:48 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Correct 70 b-body with power disc's.
Re: 1970 b-body power disc brake booster/master cylinde [Re: 62maxwgn] #147686
11/14/08 02:25 PM
11/14/08 02:25 PM
Olympia WA
rocketresto Offline
rocketresto  Offline
Olympia WA
I think that in 1970 the exit on the master has to do with which brass block system is in the car. Two blocks get the fender exit master and the more common three block system gets the engine exit master. I know Dans GTX doesn't have the third valve on the frame rail, and would be willing to bet that HPMikes R/T dosen't either.
Mike
Re: 1970 b-body power disc brake booster/master cylinde [Re: rocketresto] #147687
11/14/08 02:49 PM
11/14/08 02:49 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I have a NOS 70B body non-hemi PDB master cylinder in orig Mopar box dated Jul69. Its completely black, incl cap, and the outlet ports face the engine.
Re: 1970 b-body power disc brake booster/master cylinde [Re: 70runner] #147688
11/14/08 05:29 PM
11/14/08 05:29 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Galen once told me that Superbirds could come either way. I have a bird with the lines to the outside and my buds bird is on the engine side. Both are low mileage cars believed to be original and 440 cars.
Re: 1970 b-body power disc brake booster/master cylinder ?? [Re: 6bblgt] #147689
11/15/08 02:21 AM
11/15/08 02:21 AM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Here's a shot of my '70 Superbee, St Louis built on Sept 24th.
Re: 1970 b-body power disc brake booster/master cylinde [Re: fastmark] #147690
11/15/08 10:21 AM
11/15/08 10:21 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Galen once told me that Superbirds could come either way. I have a bird with the lines to the outside and my buds bird is on the fender side. Both are low mileage cars believed to be original and 440 cars.
More than once Galen has made statements that are not correct.I have yet (in 30 yrs) to see a bird with the "original" master cylinder that does not have the lines on the engine side.
Re: 1970 b-body power disc brake booster/master cylinde [Re: 62maxwgn] #147691
11/15/08 12:37 PM
11/15/08 12:37 PM
Crook County, ILL
Crook County, ILL
Several years ago I was parked next to a real nice Daytona at a local show, and noticed that it had a '71 up disc brake master cylinder on it. I diplomatically mentioned to the owner that the master cylinder was wrong but I had a correct NOS one at home that I'd sell him for a good price. The guy flipped out on me, told me "Galen Govier looked at my car, he told me everything wrong with it, he didn't tell me the master cylinder was wrong, if it was he would have told me! And Chrysler would have never run the brake lines on the engine side because of the heat!"
A few months later I got my new Mopar Collector Guide and I was reading Galen's column. In it he mentioned that a customer whose car he'd recently evaluated had called him and told him someone at a car show had told him his master cylinder was wrong. Galen went on to say that he had been studying cars and records for years, and didn't know everything, but basically did know everything and that the guy should say that Galen had looked at the car and said it was correct, therefore it is correct.
Funny, he had to be talking about me and that Daytona.
The blind leading the blind..........
Re: 1970 b-body power disc brake booster/master cylinde [Re: Mastershake340] #147692
11/15/08 12:39 PM
11/15/08 12:39 PM
Crook County, ILL
Crook County, ILL
By the way, recently a correct appearing lines on the engine side master cylinder has started to be sold through the aftermarket. I think Napa sells it as a rebuilt even though it is new (Chinese).
Re: 1970 b-body power disc brake booster/master cylinde [Re: Mastershake340] #147693
11/16/08 08:40 PM
11/16/08 08:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
hhhmmm , I wonder if it's the one someone else sells and won't give a price on their website ???
Re: 1970 b-body power disc brake booster/master cylinde [Re: JohnRR] #147694
11/16/08 09:04 PM
11/16/08 09:04 PM
Gladstone, Michigan
UP FM3challenger Offline
Gladstone, Michigan
how about a napa part number for the correct (but chinese) one?
Re: 1970 b-body power disc brake booster/master cylinde [Re: UP FM3challenger] #147695
11/16/08 09:25 PM
11/16/08 09:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I seen it at Carquest stores, their number is m1614...Autozones number should be m1475...not a bad looking repro, has no part numbers cast in the bottom, like an original.....casting shape, and bail wire is slightly different, but you wouldn't know unless you were looking for the difference......retail is approx $50
