Re: 1970 b-body power disc brake booster/master cylinde
[Re: 6bblgt]
#147680
11/13/08 07:09 PM
11/13/08 07:09 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Re: 1970 b-body power disc brake booster/master cylinder ??
[Re: 6bblgt]
#147681
11/13/08 07:16 PM
11/13/08 07:16 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
thanks Mike, What plant & SPD is your black car? I know my M/C is incorrect, there was a NOS unit on the 'bay with the lines toward the engine listed as '70 b-body w/power disc brakes. Evidently they came both ways, WHY/WHEN/WHERE???
My R/T has a SPD of 7/14/70 and it is a St. Louis car. I never checked, but it must be one of the last 6 pk. R/T's produced.
[Re: Mastershake340]
#147684
11/14/08 01:30 AM
11/14/08 01:30 AM
JohnRR
U.S.S.A.
Disc brake master cylinders for '68-'70 B bodies have the lines toward the engine except for hemis. The hemi and non hemi application disc brake master cylinders are basically the same 1-1/8" bore parts internally, so why they changed to the line toward the engine style in '68 I can't even speculate (in '67 all B body master cylinders had lines toward the fender). For the last over 20 years, the only replacement 1-1/8" cylinder available new for these applications was the line toward the fender style, which probably explains why you see that part on so many cars. Many would rather rebend brake lines than try to find the lines toward engine style cylinder. If you check the Chrysler part numbers for B body master disc brake numbers you will find the part numbers for non-hemi are for the line toward engine style. The cylinder shown in that picture on the green car is an aftermarket '71-'75 disc brake cylinder and the brake lines are not bent in an OE manner.
[Re: 70runner]
#147688
11/14/08 05:29 PM
11/14/08 05:29 PM
Posts: 6,389 Abilene, Texas
fastmark
Abilene, Texas
Galen once told me that Superbirds could come either way. I have a bird with the lines to the outside and my buds bird is on the engine side. Both are low mileage cars believed to be original and 440 cars.
[Re: fastmark]
#147690
11/15/08 10:21 AM
11/15/08 10:21 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Galen once told me that Superbirds could come either way. I have a bird with the lines to the outside and my buds bird is on the fender side. Both are low mileage cars believed to be original and 440 cars.
More than once Galen has made statements that are not correct.I have yet (in 30 yrs) to see a bird with the "original" master cylinder that does not have the lines on the engine side.
[Re: 62maxwgn]
#147691
11/15/08 12:37 PM
11/15/08 12:37 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Several years ago I was parked next to a real nice Daytona at a local show, and noticed that it had a '71 up disc brake master cylinder on it. I diplomatically mentioned to the owner that the master cylinder was wrong but I had a correct NOS one at home that I'd sell him for a good price. The guy flipped out on me, told me "Galen Govier looked at my car, he told me everything wrong with it, he didn't tell me the master cylinder was wrong, if it was he would have told me! And Chrysler would have never run the brake lines on the engine side because of the heat!" A few months later I got my new Mopar Collector Guide and I was reading Galen's column. In it he mentioned that a customer whose car he'd recently evaluated had called him and told him someone at a car show had told him his master cylinder was wrong. Galen went on to say that he had been studying cars and records for years, and didn't know everything, but basically did know everything and that the guy should say that Galen had looked at the car and said it was correct, therefore it is correct. Funny, he had to be talking about me and that Daytona. The blind leading the blind..........
#147693
11/16/08 08:40 PM
11/16/08 08:40 PM
JohnRR
U.S.S.A.
By the way, recently a correct appearing lines on the engine side master cylinder has started to be sold through the aftermarket. I think Napa sells it as a rebuilt even though it is new (Chinese).
hhhmmm , I wonder if it's the one someone else sells and won't give a price on their website ???
[Re: UP FM3challenger]
#147696
11/16/08 09:28 PM
11/16/08 09:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
#147697
11/16/08 09:30 PM
11/16/08 09:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: JohnRR]
#147698
11/16/08 09:32 PM
11/16/08 09:32 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#147699
11/16/08 10:07 PM
11/16/08 10:07 PM
JohnRR
U.S.S.A.
This is an original , that is not painted the color it should be .
fixed
[Re: JohnRR]
#147700
11/17/08 01:59 AM
11/17/08 01:59 AM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
Can anyone post the correct casting numbers for the master cylinders?
E B Hemi and non hemi.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: BS27R1B]
#147701
11/17/08 02:14 AM
11/17/08 02:14 AM
Mastershake340
Crook County, ILL
List of disc brake casting numbers from my master cylinder article published in Mopar Action April '05: Disc brake master cylinder casting numbers Note: first casting number in list should be 2225541
[Re: NANKET]
#147703
11/17/08 02:17 AM
11/17/08 02:17 AM
Mastershake340
Crook County, ILL
Where do we buy a rebuild kit for the original 1970 engine side master cylinder?
Napa and Raybestos have a kit for 1-1/8" bore master cylinders.
[Re: ademon]
#147705
11/18/08 12:14 AM
11/18/08 12:14 AM
fastmark
Abilene, Texas
I know Galen makes mistakes, but both of these birds have nice lines on them and pretty obvious that they have the original masters on them. 20 or 30 years ago when someone bought the wrong master and just twisted the lines over on the other side, they did not tend to do a good job at making them look straight. I believe both cars have the original lines in the correct orientation and yet they are both 440 cars with lines on opposite sides. Another thing that you probably will not agree on is the fact that neither of my friends two Superbirds had the vin number stamped on the rad support. Both had it on the trunk lip. Again, Galen said that was common on Superbirds. The problem is that I mentioned Galen and people on this board love to throw stones at him. That my 2 cents worth.
When I first bought my bird in 1979, I went to the Chrysler dealership and bought three masters for my AAR cuda and three for my 440 Superbird. All of the ones for the bird came with the lines to the engine side
[Re: fastmark]
#147706
11/18/08 09:57 AM
11/18/08 09:57 AM
62maxwgn
Blair County,PA
On that one I have to agree with you.My bird has none and a friends B5 bird also nas none.
