Recurving a 4 speed shaft #1476572
07/30/13 06:45 PM
07/30/13 06:45 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
A buddy of mine made a purchase about 2 months ago. Bought a 72 Roadrunner off eBay...it arrived here and he is having a hell of a time driving it. Its a 440 4 speed with an air grabber. He is a big boy. About 6'2 and 350 lbs...He complains he cant shift into gears correctly because his legs get in the way of the shifter.
I told him to bring it by this week and have a look. I am going to relocate his seat mechanism back about 6 inches, weld in some steel square tubing and plant it back down...Afterwards...I want to remove his shifter and get a 5/16" rebar...curve it around his leg and where he can still grab the shifter ball comfortably. I'll take the rebar then and heat up some 1/2" steel rod and bend it up with the rebar template....attach it back into place...and if he likes it and can use it correctly...then I will send it out for a chrome finish and figure out the ball assembly on the end..
Am I going about this correctly though? I have never done such a thing but he knows I am the most qualified in the area to tackle this feat.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476573
07/30/13 07:02 PM
07/30/13 07:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Sounds like the right approach. Some of these cars (even the bigger ones) are a tough fit for big people. I get a kick out Shaq in the Buick commercial as he looks very uncomfortable with his knees in his face, etc.
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476574
07/30/13 08:02 PM
07/30/13 08:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Is the shifter in the bench seat location or bucket seat location.If bench seat get a bucket seat hump and everything to move the shifter to the back of the transmission.
Re: Recurving a 4 speed shaft [Re: 71birdJ68] #1476575
07/30/13 09:12 PM
07/30/13 09:12 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I know the car has buckets but it is unknown to me which of the two locations it is installed at...I didn't know there was a difference really. Never owned an old school manual.
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476576
07/30/13 11:05 PM
07/30/13 11:05 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The bench seat and bucket seat with a buddy seat or fold down arm rest has the shifter all the up at the dash so the seat can go back and forth and clear. The bucket seat with a console the shifter is way back like an E body car. And the tail shaft housing will have two shifter mounts also,if its a late model trans. one forward and one almost at the end.So that means that the humps are also different. If its in the forward location, he can buy the other hump and swap them. Move the shifter and buy the longer shift rods, and then there will be a lot more room.
Re: Recurving a 4 speed shaft [Re: 71birdJ68] #1476577
07/31/13 03:55 PM
07/31/13 03:55 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Took a picture of the shifter today...I havent touched it yet. I am going to relocate his seat back 6" and then we will go from there. Which version is this?
Is this how they actually came because that looks alot like a hacked up automatic console
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476578
07/31/13 04:18 PM
07/31/13 04:18 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
That looks like an E-body pistol grip to me. I am sure others will chime in. The b-body bench seat ones are taller and move to the right about 2-3 inches. FWIW attached is a pic of a 71-74 B-Body Bench seat handle in my A-body
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476579
07/31/13 04:19 PM
07/31/13 04:19 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
FWIW, The console top plate shown is a 4-speed top plate, not an automatic.
Re: Recurving a 4 speed shaft [Re: 318 Stroker] #1476580
07/31/13 04:25 PM
07/31/13 04:25 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
#2
Re: Recurving a 4 speed shaft [Re: Pyper70] #1476581
08/01/13 12:57 AM
08/01/13 12:57 AM
IMGTX Offline
IMGTX  Offline
That is the correct shifter and console for a 71-74 B body. They used the same setup as the e-bodies.
The console looks like an Automatic console but the top has a larger hole and the bottom side has a larger cutout. Both to clear the shift boot.
They did make a non console shifter that mounted in the floor farther forward but the floor pan is different. The squarish tunnel that the shifter sits in is shorter and does not extend back as far as the one you have.
