Sox & Martin carb linkage info/photos required.
Ron gave me these alloy Sox & Martin throttle brackets & I have a complete Enderle linkage to rob the other parts required but I have no idea where the bottom Sox & Martin bracket/plate goes.
The holes are spaced to match the tunnel ram top to bottom bolts but this means the bracket could fit on the LH side at the back, across the back, RH on the side at the front or across the front.
I have seen so many different linkages on S & M cars that I'm totally confused as to where this bracket goes so any info or pics would be great. Thanks.
