Dana 3.31-3.33 gears: Can they be found? #1476502
07/30/13 03:09 PM
07/30/13 03:09 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've heard and read about rumors of a few sets hanging around.
https://board.moparts.org/ubbthreads/showflat.php?Number=6252443&page=0
https://board.moparts.org/ubbthreads/showflat.php?Number=5412888&page=0
https://board.moparts.org/ubbthreads/show...amp;Search=true
Id like to get a set before I buy a 3.54 set.
Where should I start looking?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Dana 3.31-3.33 gears: Can they be found? [Re: AlexP] #1476503
07/30/13 04:16 PM
07/30/13 04:16 PM
Dana never made 3.30 gears for the Dana 60, only for the Dana 61 rear ends
Re: Dana 3.31-3.33 gears: Can they be found? [Re: Cab_Burge] #1476504
07/30/13 06:05 PM
07/30/13 06:05 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Yes..that is true..I happened to find a Dana 61 in a 1985 Ford Truck...with 3:07 rear gears for my project!...Hard to find...the 3:07 and 3:31 rear gears are only offered in the Dana 61 in early to mid 80's Ford 3/4 ton 2WD trucks
Re: Dana 3.31-3.33 gears: Can they be found? [Re: GLR] #1476505
07/30/13 06:34 PM
07/30/13 06:34 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The early non-overdrive 5.9 Cummins D250 and D350 had the 3.07 gears too.
- Stu Harmon
Re: Dana 3.31-3.33 gears: Can they be found? [Re: feets] #1476506
07/30/13 06:40 PM
07/30/13 06:40 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And the 66/67 Dana 53 in the C body was available with 3.31.
Re: Dana 3.31-3.33 gears: Can they be found? [Re: 62maxwgn] #1476507
07/30/13 11:15 PM
07/30/13 11:15 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
I disagree guys, I have 3.33 gearset that I bought for my dana 60 from a member here. I admit that I haven't tried to install them yet, but when I was looking for some, the info I dug up indicated that 78 or 79 ford F250 pickup trucks were available with 3.33 gears in a dana 60. Can't say what carrier they would require.
my
Jess
Yeah, it's hopped up to over 160...
Re: Dana 3.31-3.33 gears: Can they be found? [Re: jt4406] #1476508
08/02/13 02:22 PM
08/02/13 02:22 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have 3.33`s in my Satellite. It is a Ford truck Dana-60.
Do not know its origin.
I`m looking to change the gears to 3.73. PM me if interested
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Dana 3.31-3.33 gears: Can they be found? [Re: 6bblFLASH] #1476509
06/30/14 02:46 PM
06/30/14 02:46 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Still looking for a set...
Re: Dana 3.31-3.33 gears: Can they be found? [Re: 6bblFLASH] #1476510
06/30/14 03:28 PM
06/30/14 03:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
From what I have read you may have a Dana 61. I think they look almost identical except the pinion is offset to accommodate the bigger pinion of the 3.xx gears.
Kevin
Re: Dana 3.31-3.33 gears: Can they be found? [Re: Twostick] #1476511
06/30/14 10:34 PM
06/30/14 10:34 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Thay did make 3.33 I have a set in a 1969 b body Dana 60
