putting dual exhaust on 84 ramcharger 4x4 ? #1476179
07/29/13 09:01 PM
07/29/13 09:01 PM
northeast ohio
hulmule Online content OP
hulmule  Online Content OP
northeast ohio
playing around with this 84 ramcharger I just picked up. needs a muffler and tail pipe. thinking if someone made a dual kit? possible headers so I can remove that dang catalytic converter and let the motor put out it's aprox full 185 hp lol finding parts here and there guys are getting out of. What do ya think?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: hulmule] #1476180
07/29/13 09:52 PM
07/29/13 09:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NO need for duals on a 185 hp engine. I just put headers/Hooker Aero Chamber muffler and a homemade 2.5 mandrel bend system on mt 81 360 CC Dually.. Sounds great !!! More than adequit.
I am truckless..
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: 340SHORTY] #1476181
07/29/13 09:56 PM
07/29/13 09:56 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I run a single system with no cat or mufflers all the way out back.
Not loud at all, until I get into it.
I have mechanical Aptitude.
I can screw up anything.
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: bboogieart] #1476182
07/30/13 01:51 AM
07/30/13 01:51 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
a dual exhaust fan myself. Im going to be putting 2.5" duals ony stock 5th ave. Go to summitracing.com they carry dual kits and remember truck and rc's array basically the same so headers fit from a truck.
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: 76dodgeboy] #1476183
07/30/13 01:53 AM
07/30/13 01:53 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I had duals on my stock 84 Rc also. Just don't try and run 3" duals. That's too much
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: 76dodgeboy] #1476184
07/30/13 09:12 PM
07/30/13 09:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Me too but the gas tank is in the way, and it already had a good y pipe.
Just cost the price of the pipes.
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: bboogieart] #1476185
07/30/13 09:41 PM
07/30/13 09:41 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
The gas tank on the Ramcharger is between the frame at the rear.
I have plenty of room with duals on the RC. The pipes run to the rear and turn out in a factory style, one per side of course.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: hp383] #1476186
07/31/13 02:04 AM
07/31/13 02:04 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You must be use to straight back duals. As Jamie state its also alt easier to run dual on an RC
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: 76dodgeboy] #1476187
08/02/13 12:08 PM
08/02/13 12:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yeah I know they run em down the same side, but cost was a consideration for me. Just a few bucks. My junk ain't worth dumping much cash into.
Had no idea R/Cs were different. It does sound good to me and not loud when driving conservatively.
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: bboogieart] #1476188
08/02/13 01:04 PM
08/02/13 01:04 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Same side? Rc you can run them clear back on each side. Trucks Have to be down one side do to saddle tank
Quick search on summit
http://www.summitracing.com/search/depar...odel/ramcharger
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: 76dodgeboy] #1476189
08/02/13 01:22 PM
08/02/13 01:22 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I said I had no idea R/Cs were different. I live I learn.
Re: putting dual exhaust on 84 ramcharger 4x4 ? [Re: bboogieart] #1476190
08/02/13 01:30 PM
08/02/13 01:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ok I wasnt sure if what you meant. If you dont want duals order
http://www.summitracing.com/parts/wlk-40491/overview/make/dodge/model/d350/year/1984
run 2.5" back and through the muffler to this(modifications may be needed for this ie cutting it shorter)
http://www.summitracing.com/parts/wlk-45105
Doing this to my 75 rite now
