440 RV engine making noise...CAm ?? Lifters ? #1476163
07/29/13 09:00 PM
07/29/13 09:00 PM
Connnecticut
acesneights Offline OP
Connnecticut
I have a very slight noise coming form the motor that sounds like a diesel idling but it is quieter than that. I poked around the engine with my stethoscope and I can hear it loudest on the valley pan towards the front of the engine and also on the drivers side valve cover towards the front of the engine. I just had the intake off and everything looked ok but could it be a bad cam ?
It runs pretty good overall. Has plenty of power. Motor is a 1975 440 in and RV and has 99k miles on it.
Does not burn any noticeable oil and really no oil smoke at all. No blow by.
It's not a ticking sound, is not a knocking sound. It's more like a very slight marbley sound. Oil pressure is good.
I was told by someone on my RV forum that these engines need zinc additive to the engine oil ?? But he also mentioned something a bout flat tappet and this motor has hydraulic lifters. I will see if I can record the noise with my phone but it won't be easy. As soon as I put the hood back on you can't even hear it. I do not hear it when off idle.
1975 Dodge Travco 440 BB 1972 Dodge Travco 318 SB
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476164
07/29/13 09:05 PM
07/29/13 09:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Flat tappet is a lifter type , they come in both solid and hydraulic. You need a good zinc oil , the current oils on the market are made for new cars with roller cams and they do not need nearly the zinc the old engines do.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: JohnRR] #1476165
07/29/13 09:21 PM
07/29/13 09:21 PM
Connnecticut
Connnecticut
I have put about 7-800 miles on it so far do you think I damaged anything ? I am working on the video as I type.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476166
07/29/13 09:23 PM
07/29/13 09:23 PM
Connnecticut
Connnecticut
I put Valvoline 20/50 racing in it last oil change.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476167
07/29/13 09:23 PM
07/29/13 09:23 PM
Connnecticut
Connnecticut
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476168
07/29/13 09:39 PM
07/29/13 09:39 PM
Connnecticut
Connnecticut
What Oil should I use ?
Lucas makes a classic car and hot rod oil that boasts high ZDDP. Also Valvoline makes a not for street oil.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476169
07/29/13 11:40 PM
07/29/13 11:40 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Welcome to Moparts. Another Travco nut could make it over! I'm over on Travcoforum as well.
Ryan
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: Devil] #1476170
07/29/13 11:52 PM
07/29/13 11:52 PM
IN
ahy Offline
ahy  Offline
IN
For the oil, to get adequate zinc I run diesel engine oil in my flat tappet. Shell Rotella T. Another option is dedicated classic car oil with higher zinc like Joe Gibbs. Yet another is standard car oil with a zinc supplement like Comp Cams break in supplement.
If you are worried about the cam, probably best to pull the intake, roll the engine over and have a close look at the lobes. Only because cam failure can create debris and collateral damage. I would add that an engine with moderate cam already broken in may not be as sensitive to lube oil. New cam/new lifters can be quite sensitive.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: ahy] #1476171
07/29/13 11:56 PM
07/29/13 11:56 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Are you sure its not an exhaust leak at the manifold? RV s ate notorious for warping exhaust manifolds and it sounds similar to a lifters tick.
Keith
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476172
07/30/13 03:44 AM
07/30/13 03:44 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Quaker State 10W-30 Defy, API SL synthetic blend is said to have 1200 ppm zinc. You can get it at Walmart in 5 qt jugs. I used it the other day.
Before that I used regular SN 10w-30 for 7 months with no harm done. This is in 383 RR with factory-type valvetrain and vintage original springs.
68 Roadrunner. 383 4-spd. Beat up.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: Dunnuck Racing] #1476173
07/30/13 08:11 AM
07/30/13 08:11 AM
Connnecticut
Connnecticut
Keith
Yeah the passenger side ones always crack due to the heat riser.
Mine has already been replaced. I saw some very slight greyish sludge deposits in the bumps between the lifters butthe motor has 99k . Nothing I would call unusual.
It sounds like my vw tdi but not as loud. Im worried that it's a cam bearing.
What would that sound like ?
Also to check the cam could pull the valve covers and use a dial indicator ?
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476174
07/30/13 09:38 AM
07/30/13 09:38 AM
scratchnfotraction Offline
Keith
IMHO, same thing in my 77 440 MH engine. sloppy t-chain and mech fuel pump pumping away.
removed the fuel pump and replaced chain,results = less noise.
now i broke a rear exhaust stud and warped a manifold cant hear nothing but exhuast leak and the elect fuel pump in the back.
IIRC, this is why some BB had the pillow under the intake in the valley, to muffle the mechanical engine noise of the valvetrain.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: scratchnfotraction] #1476175
07/30/13 06:12 PM
07/30/13 06:12 PM
Connnecticut
Connnecticut
So those noises are normal given the age of the engine ?
I keep a good supply of Rotella 15-40 for all my diesels.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476176
07/30/13 06:48 PM
07/30/13 06:48 PM
maybe, maybe not. could just be the mech noise an engine makes or could be from slight wear from use, could be both, could be getting worse, maybe not.
todays oils with high milage slider cams..
I run a 15w40 diesel oil from napa and let it rip. it had 75,000 miles on it,pulled,sat 3yrs,went back into service in 10' running the snot out of it.
I got to the point I had to stop worrying about the oil/slider cam/wear/noises/leaks and just get on with it.
fires right up, idles good cold, warms up fine, 200-300 mile trip with no troubles. gets 15 mpgs if i stay at 2000 rpm with the stock MH cam.
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: scratchnfotraction] #1476177
07/30/13 10:14 PM
07/30/13 10:14 PM
Connnecticut
Connnecticut
I can pull the valve cover real easy. WOuld it be worth putting a dial indicator on it ?
I don't know the specs for this motor but I would assume all 4 cyls on that side should read the same and if one was way off...
Re: 440 RV engine making noise...CAm ?? Lifters ? [Re: acesneights] #1476178
07/30/13 10:23 PM
07/30/13 10:23 PM
Connnecticut
Connnecticut
here was the motor with intake off.
