LA top end reassembly #1476159
07/29/13 08:47 PM
07/29/13 08:47 PM
MNobody Offline OP
MNobody  Offline OP
Can someone plz give me the head torque # and any intake sealing tips i would appreciate it. First smallblock i'm a newbie lol
Re: LA top end reassembly [Re: MNobody] #1476160
07/29/13 09:33 PM
07/29/13 09:33 PM
90 lbs on the head bolts. I would use the Felpro intake gaskets that are black fiber with the blue borders around the ports (might be printoseal?) & spray them with Permatex "high tack" the red stuff in the spray can part # MA99 iirc. I would not use the front/rear supplied gaskets & use a wide/even carefully placed swath of silicone instead on front/rear surfaces surgically cleaned with brake kleen or similar then after torquing the intake let it set up overnight.
Re: LA top end reassembly [Re: RapidRobert] #1476161
07/29/13 10:33 PM
07/29/13 10:33 PM
MNobody Offline OP
MNobody  Offline OP
Thank you sir!
