Re: torque converters
[Re: ultimatelenny]
#1476152
07/30/13 02:31 PM
07/30/13 02:31 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not all 518's are lockup, if the 518 is non-lockup the 727 converter will work.
904 converter won't fit any 518.
[Re: John_Kunkel]
#1476153
07/30/13 04:02 PM
07/30/13 04:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I had to go to the 518 non lock up input and I changed pumps at that time also so I could use a standard 727 high stall conv in my 518
[Re: ultimatelenny]
#1476154
07/30/13 05:11 PM
07/30/13 05:11 PM
Posts: 5,894 Florida
Locomotion
No, different spline counts. The 518 is a lock up and the 727/904 is not.
Many 727's and 904's become lock-up starting in the late '70's.
[Re: 72sat]
#1476156
07/30/13 11:15 PM
07/30/13 11:15 PM
MR_P_BODY
so,how do I identify a lock-up and non lock- trans? and converters?
The lock up conv is big... as far as I know they only built the one diameter and its like 11.5... on the trans that pretty easy... if you have a 518 and its a 1 pin connector that is OD only... a 3 pin is OD and lock up... you dont want the 7 pin one.. thats a computer controlled one and is all electrical controlled
[Re: 72sat]
#1476157
07/30/13 11:22 PM
07/30/13 11:22 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
Look at the end of the input shaft, if there's a hole going deep into it it's a lockup.
