Nonlinear Brakes #1476118
07/29/13 07:28 PM
07/29/13 07:28 PM
Charleston, SC
bronco9588 Offline OP
Charleston, SC
So I have changed out rear drum brake pistons, rebuilt front calipers, new flexible hoses, new stainless steel lines I ran her for a little while on that setup, and then purchased a new master cylinder and brake booster. Now I have 0 braking effort for 90% of the travel and then the brake kicks in a the last second and locks up.
I have bled my brakes twice with no noticeable effort. I think I have one of two problems:
1) Push rod adustment: I don't feel like the brake pedal is loose and that the pushrod is making contact further down the travel. It wouldn't explain the brakes locking up. Are these guys compatable with brake boosters?
http://chucker54.stores.yahoo.net/brakcylpuspa.html
2) Do I need to bench bleed the master cylinder?
'73 Charger Petty Blue, Black Vinyl, and Gill Slits 727 torque-flight 400 BB Chrysler 8 3/4 rear
Re: Nonlinear Brakes [Re: bronco9588] #1476119
07/29/13 08:09 PM
07/29/13 08:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you properly adjust the rear shoes?
Don't be the exception.
Re: Nonlinear Brakes [Re: Supercuda] #1476120
07/29/13 08:18 PM
07/29/13 08:18 PM
Charleston, SC
Charleston, SC
No, but they were working before I swapped out the master and the booster. I then drove 1,000 miles. If they were off, would they not have adjusted by then? This problem showed up after the master cylinder and booster swap.
Re: Nonlinear Brakes [Re: bronco9588] #1476121
07/29/13 08:33 PM
07/29/13 08:33 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Are you saying you did not bench bleed the master before you installed it?
Re: Nonlinear Brakes [Re: EV2DEMON] #1476122
07/29/13 08:38 PM
07/29/13 08:38 PM
Charleston, SC
Charleston, SC
That is correct. I have a pair of old brake lines that I can use to do the job. I think after my reading that this is probably the problem.
Why would the brakes lock up so quickly?
Re: Nonlinear Brakes [Re: bronco9588] #1476123
07/29/13 10:10 PM
07/29/13 10:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That statement tells me you fooled with the rear brakes. Mind you the rear brakes will only self adjust if, A. the self adjusters are properly assembled and working and B. they only self adjust when you stop while going backwards.
How many of those 1000 miles were your stopping while going backwards? The self adjusters are really only there to compensate for wear, not to correct maladjustment, though it will eventually do so.
And yes, you should always bench bleed your M/C, make sure you have a cover on it and do not stomp the pedal or you will squirt brake fluid all over the place.
Re: Nonlinear Brakes [Re: bronco9588] #1476124
07/30/13 05:08 PM
07/30/13 05:08 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
also make sure that the master cyl pushrod isn't too long (master cyl preload - there shouldn't be any) this won't allow the cylinder to fill correctly because the piston/seal covers the compensating port in the bore
Re: Nonlinear Brakes [Re: bronco9588] #1476125
07/31/13 05:27 PM
07/31/13 05:27 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
did you switch from manual to power brakes?
Probably not it... but some of these cars had different brake pedal lengths/pivot points/ratios for the booster rod and that can happen.
We switched from manual to power on my bothers 70 Fury and it did the same thing... nothing for 90% of travel then lock up... Changed out the pedal and all fixed. didnt make sense... but... hey
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: Nonlinear Brakes [Re: ntstlgl1970] #1476126
08/02/13 01:08 AM
08/02/13 01:08 AM
Charleston, SC
Charleston, SC
How do you go about setting this?
Re: Nonlinear Brakes [Re: bronco9588] #1476127
08/02/13 02:14 AM
08/02/13 02:14 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
- This is not something you run into very often -
Loosen the master cylinder and see if there is any resistance when you attempt to push the master towards the firewall which would indicate preload. There should be no resistance. Or if you have a dial caliper, you can measure the depth of the pushrod bore in the master vs. the length the pushrod from the firewall to the end of the pushrod.
Another possibility - if there is preload - loosen the brake lamp switch - it doesn't take much preload to mess things up.
