331 hemi marine carter carburator accelerator pump. #1476115
07/29/13 06:38 PM
07/29/13 06:38 PM
CA
hemi1head Offline OP
CA
Yes, I have a 1955 Chris-Craft with a 331 Hemi with the twin single Carter Carburators on it. I want to keep them original. I found that my accelerator pumps need replacing. Found a similar one on Carbx.com
My numbers are a 2221S, the closest one on Carbx is a 2018T. Is there anyone out there that can tell me if this work? Thanks.
Re: 331 hemi marine carter carburator accelerator pump. [Re: hemi1head] #1476116
07/29/13 07:49 PM
07/29/13 07:49 PM
Contact Scott Harms (on here) first priority or "the carburetor shop" in Eldon missouri 573-392-7378
Re: 331 hemi marine carter carburator accelerator pump. [Re: RapidRobert] #1476117
07/29/13 10:06 PM
07/29/13 10:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Does your original pump have a spring or is it a solid brass shaft with no spring?
