16" rims on a 84 ramcharger?? #1476084
07/29/13 05:29 PM
07/29/13 05:29 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
looking at a change of tires and rims. will the 1994 till 2001 1/2 ton rims fit on a 84 4x4 ramcharger? Is that the same bolt pattern? anyone done this?thanks any pics?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 16" rims on a 84 ramcharger?? [Re: hulmule] #1476085
07/29/13 05:39 PM
07/29/13 05:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
They will bolt on but the offset is wrong.. These are 16x8 American Racing wheels on my demised 87..
I am truckless..
Re: 16" rims on a 84 ramcharger?? [Re: hulmule] #1476086
07/29/13 05:44 PM
07/29/13 05:44 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
When I tried, the hole in the middle was to small for the hub to fit on the front. There could be different runs of them though that have different sized center holes.
Re: 16" rims on a 84 ramcharger?? [Re: CTD5.9] #1476087
07/29/13 07:16 PM
07/29/13 07:16 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They Wot fit do to the small hub hole. You either have to run a Space or have the hole machine. I personally think 94-01 wheels are hideous accept for the steelies.
Re: 16" rims on a 84 ramcharger?? [Re: 76dodgeboy] #1476088
07/29/13 07:17 PM
07/29/13 07:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Also if your Rc is 2wd the bolt pattern will be different.
Re: 16" rims on a 84 ramcharger?? [Re: 76dodgeboy] #1476089
07/29/13 08:54 PM
07/29/13 08:54 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
it's a 4x4 just looking for options. don't want to buy new rims. looking at used stuff, finding different things on craigslist. want to keep my option open.
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 16" rims on a 84 ramcharger?? [Re: hulmule] #1476090
07/29/13 09:43 PM
07/29/13 09:43 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Won't 5 on 5 1/2 aftermarket Ferd rims work? Autta be lots of those out there reasonable.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 16" rims on a 84 ramcharger?? [Re: old_goat] #1476091
07/30/13 01:43 AM
07/30/13 01:43 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
So how exactly are they aftermarket ford wheels? ANY Aftermarket rim that ate 5x5.5 should fit. I have yet to see any with a Small hub hole. Factory Ford truck rim might work.
Re: 16" rims on a 84 ramcharger?? [Re: 76dodgeboy] #1476092
07/30/13 10:05 AM
07/30/13 10:05 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
My 84 RC had 5 on 4 1/2 BC, I ran cop wheels on it. In 85 that was changed to 5 on 5 1/2 BC. I'm pretty sure that standard for all 1/2 ton trucks.
Re: 16" rims on a 84 ramcharger?? [Re: wedgeheaded] #1476093
07/30/13 11:15 AM
07/30/13 11:15 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
2was were 4.5" till 85 yes HOWEVER 4wds went back to 5.5" in 1980
Re: 16" rims on a 84 ramcharger?? [Re: 76dodgeboy] #1476094
07/31/13 11:54 AM
07/31/13 11:54 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
2was were 4.5" till 85 yes HOWEVER 4wds went back to 5.5" in 1980 [/quote
Didn't know that, thought they were the same. Thanks
