INTERESTING CODE GENERATING
#1475934
07/29/13 02:37 PM
07/29/13 02:37 PM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
95 Concorde, 3.5
On occasion, the "check engine" light would come on, but when I'd shut it off, it'd clear it and not come back on for some time. Got to where it'd come on not when it was running, but after I'd start out, maybe on the 2-3 upshift or 25 or so MPH.
This car runs fine, no odd shifts or actions. Anyone ever run across this? I've not had it to a place to decode it. I've done the 3 on/off thing, but it flashes codes, but not what appears to be one, but a series. I should I guess count them and see?
Thoughts
Re: INTERESTING CODE GENERATING
[Re: In_The_Pink]
#1475937
07/29/13 04:34 PM
07/29/13 04:34 PM
Posts: 21,838 Kirkland, Washington
Pacnorthcuda
Yes, re-do the key dance, and count the flashes. All codes are two numbers, so flash-pause-flash-flash-flash = 23, etc.
55 should be the last code you get, which means the end of codes.
Um....wouldn't your example be 13?.....not 23???
