Can stripes be removed without damaging paint? #147559
11/08/08 10:47 PM
11/08/08 10:47 PM
State, country, etc.
gss Offline OP
gss  Offline OP
Tape stripes about 3" wide running the length of the car have been on for 4 years. They are slightly crooked and I would like to replace them. Can it be done?
Re: Can stripes be removed without damaging paint? [Re: gss] #147560
11/08/08 10:52 PM
11/08/08 10:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
yes..Lots of ways to remove them, heat gun, decal stripping wheel, just grab an edge & carefully peel....Once removed if the paint is oxidized you'll need to buff the paint so the old decal location doesn't show...
Re: Can stripes be removed without damaging paint? [Re: 1_WILD_RT] #147561
11/09/08 09:00 AM
11/09/08 09:00 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Re: Can stripes be removed without damaging paint? [Re: CYACOP] #147562
11/09/08 10:49 AM
11/09/08 10:49 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
after 4 years, the paint underneath will be a different color unless it's been in a cave the whole time.
Re: Can stripes be removed without damaging paint? [Re: RodStRace] #147563
11/09/08 10:52 AM
11/09/08 10:52 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
if theyve been on that long, chances are the stripes will leave indentations in the paint.
Get ready for a repaint
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Can stripes be removed without damaging paint? [Re: RangerDan440] #147564
11/09/08 11:04 AM
11/09/08 11:04 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Best bet is a heat gun. You will most likely have glue left over to remove after which is worse then pulling the stickers. You can use something like Dupont final; clean or some Prep-Sol to remove the glue. Then you will have to buff the paint out.
Chances are you will still see a shadow of wear the stripe was how bad depends on the color od the car. Worth a shot though. I just pulled all the stickers off of a Fire Chiefs car and when it was done and buffed out you couldnt tell they were there but the car was white.
How ever if you are replacing it doesnt really matter.
Re: Can stripes be removed without damaging paint? [Re: RodStRace] #147565
11/09/08 01:30 PM
11/09/08 01:30 PM
gss Offline OP
gss  Offline OP
Yes, it has pretty much been in a cave for 4 years.
Anyone else?
Re: Can stripes be removed without damaging paint? [Re: gss] #147566
11/09/08 06:49 PM
11/09/08 06:49 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
You will see the lines at an angle even after buffing, not really a way around it except repaint
Re: Can stripes be removed without damaging paint? [Re: rjsjea] #147567
11/09/08 06:55 PM
11/09/08 06:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If you read what the original poster asked he intends to replace the stripes, once the new stripes are in place you won't see any variation in the paint that is covered with a new stripe...
Re: Can stripes be removed without damaging paint? [Re: 1_WILD_RT] #147568
11/09/08 08:43 PM
11/09/08 08:43 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Thanks....he also said the were "slightly crooked" So Im guessing they wont be in the same place
Re: Can stripes be removed without damaging paint? [Re: 1_WILD_RT] #147569
11/09/08 08:45 PM
11/09/08 08:45 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
and if you think further...a heat lamp on the area you want to peel ahead of time, with a thermometer at the surface to ensure the surfaces get warm enough to peel, but not damage the paint....then peel slowly. Remove residue with glue remover, lightly wet sand affected areas with ultrafine sandpaper, buff gently and apply new decal.
Re: Can stripes be removed without damaging paint? [Re: ThermoQuad] #147570
11/09/08 10:54 PM
11/09/08 10:54 PM
gss Offline OP
gss  Offline OP
Thanks everyone! One of the stripes has a slight bow to it and one is angled down a little. I am hoping there will be no significant indentation left from the old stripe. Nothing ruins an otherwise nice restoration like some imperfect stripes.
