Re: Can stripes be removed without damaging paint?
[Re: 1_WILD_RT]
#147561
11/09/08 09:00 AM
11/09/08 09:00 AM
Posts: 3,957 SW Fla.
CYACOP
SW Fla.
yes..Lots of ways to remove them, heat gun, decal stripping wheel, just grab an edge & carefully peel....Once removed if the paint is oxidized you'll need to buff the paint so the old decal location doesn't show...
[Re: RodStRace]
#147563
11/09/08 10:52 AM
11/09/08 10:52 AM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
if theyve been on that long, chances are the stripes will leave indentations in the paint. Get ready for a repaint
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: RangerDan440]
#147564
11/09/08 11:04 AM
11/09/08 11:04 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Best bet is a heat gun. You will most likely have glue left over to remove after which is worse then pulling the stickers. You can use something like Dupont final; clean or some Prep-Sol to remove the glue. Then you will have to buff the paint out.
Chances are you will still see a shadow of wear the stripe was how bad depends on the color od the car. Worth a shot though. I just pulled all the stickers off of a Fire Chiefs car and when it was done and buffed out you couldnt tell they were there but the car was white.
How ever if you are replacing it doesnt really matter.
[Re: 1_WILD_RT]
#147568
11/09/08 08:43 PM
11/09/08 08:43 PM
Posts: 189 Portland,OR
rjsjea
Portland,OR
If you read what the original poster asked he intends to replace the stripes, once the new stripes are in place you won't see any variation in the paint that is covered with a new stripe...
Thanks....he also said the were "slightly crooked" So Im guessing they wont be in the same place
