Holley Carb #1475482
07/28/13 10:03 PM
07/28/13 10:03 PM
Burlington,Ont.
77DragracerR/T Offline OP
Burlington,Ont.
How much is the value of a power valve? How many jet sizes? The 830hp carb i have has a the power valve removed and plugged but was running with 88 jets front & rear.Factory setting is 86 with a 6.5 pv.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Holley Carb [Re: 77DragracerR/T] #1475483
07/28/13 10:17 PM
07/28/13 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've always added 7 jet sized when removing a PV and
then fine tune as needed... but 7 is very close
Re: Holley Carb [Re: 77DragracerR/T] #1475484
07/28/13 10:34 PM
07/28/13 10:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you mean the PVCRs, they vary between models of carbs. The only way to know is to pull the PV and use wire drills to measure the PVCRs. That will get you close.
Master, again and still
Re: Holley Carb [Re: MR_P_BODY] #1475485
07/28/13 11:29 PM
07/28/13 11:29 PM
Burlington,Ont.
Burlington,Ont.
Ok I'll try 7 and work from there.
Re: Holley Carb [Re: 77DragracerR/T] #1475486
07/29/13 09:31 AM
07/29/13 09:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea normally you go up 7 or 8 sizes with the PV plugged.
