cruise control stalk #1475327
07/28/13 04:50 PM
07/28/13 04:50 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
how do you disassemble the cruise control stalk of a 70 Charger? Is it possible to do it without breaking it?
the stalk looks like this:
Re: cruise control stalk [Re: DGS] #1475328
07/28/13 04:55 PM
07/28/13 04:55 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
If it's like the later stalks, there is a tiny roll pin you must drive out. I tried disassembling the pieces of a '77 stalk and it was neither fun nor successful.
Re: cruise control stalk [Re: In_The_Pink] #1475329
07/28/13 06:55 PM
07/28/13 06:55 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I didn't see a roll pin but there is a small round marking close to the button. It could be a hole that is sealed with some sort of plug maybe glued in. I'm not sure if i should try to drill it out but there is no other obvious way...
Re: cruise control stalk [Re: DGS] #1475330
07/28/13 09:49 PM
07/28/13 09:49 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I have only taken apart the later style with the sliding switch, so I'm afraid I'm not much help. My '71 B-series Compact Van factory service manual doesn't even show the Speed Control parts, and the next newest FSM I have is for '77s.
Hopefully somone can check their FSM and see if the Speed Control stalk is mentioned/pictured.
Re: cruise control stalk [Re: DGS] #1475331
07/28/13 10:13 PM
07/28/13 10:13 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
This thread does'nt directly answer your question but has an exploded view of the stalk after being taken apart and may help... LINK
Re: cruise control stalk [Re: screamindriver] #1475332
07/28/13 11:15 PM
07/28/13 11:15 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good for reference. Saved as a favorite. Thanks.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: cruise control stalk [Re: DynoDave] #1475333
07/29/13 04:52 AM
07/29/13 04:52 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Very nice, thanks!
I wrote an e-mail to the member who posted the pictures - I hope he gets back to me.
Here's the picture of the disassembled stalk (not mine - have to figure out how to do it):
Re: cruise control stalk [Re: DynoDave] #1475334
07/29/13 12:45 PM
07/29/13 12:45 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
Dont know if the 68 Charger one is the same, looks very similar. The button on the top is pressed in, takes some careful pulling to get it out with a small vice grip, I wasnt too worried about the old switch as I replaced it with a new push button from radio shack that fit perfectly as this will be my line loc button in the future.
