904 not going into 3rd all the time..... #1475170
07/28/13 08:35 AM
07/28/13 08:35 AM
Tri Cities TN area
Hailtheleaf538 Offline OP
Never Misses A Coffee Break
Tri Cities TN area
Hello all.....the 904 trans in my dart shifts early from 1st to 2nd.....going into drive, it does sometimes sometimes it doesnt. Just out aan AFB Ihad laying around the other day.....could it be the kickdown cabke needs adjusting? Im sure it coukd use a new trans, but just trying to get it right...dont wanna buy a new one right now, as I plan on having the 340 built in a stout manner maybe the winter or spring.
If I shift manually from 1st to 2nd does fine, chiros the tires.....
thanks for any help in advance, this weekend is the first chsnce ive had to really work on it
Organized Labor: The people that brought you the weekend. If you can't grasp the meaning of the phrase "tongue in cheek", don't respond. 1970 H code Swinger, Top Banana 2012 Liberty Jet 4x4 True Blue Pearl
Re: 904 not going into 3rd all the time..... [Re: Hailtheleaf538] #1475171
07/28/13 10:37 AM
07/28/13 10:37 AM
Yes shorten the kikcdown linkage a bit & see what happens. Keep track of the amount (turns) so you have a baseline & can set it back if need be & that'd be an easy solution if that is it. 2-3 shift valve may be hanging up (worst case) or maybe just need a band adjustment but I'm just guessing. I'd wait for Kunkel to come to as he's the man on this
Re: 904 not going into 3rd all the time..... [Re: RapidRobert] #1475172
07/28/13 11:08 AM
07/28/13 11:08 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
904 in a Dart should be linkage. What are you running that has a cable? I have my trannies set to be in 3rd before 35 mph on a light cruise. Need to be in 3rd when driving around town at low speeds. It won't shift into 3rd when floored before about 80 mph unless I lift off the gas.
I have mechanical Aptitude.
I can screw up anything.
Re: 904 not going into 3rd all the time..... [Re: bboogieart] #1475173
07/28/13 03:08 PM
07/28/13 03:08 PM
Tri Cities TN area
Tri Cities TN area
thanks for the responses everybody. Drove I thisbmorn and shifted great. The kickdown however. . Now it seems I got s vacuum leak csuse I cover the primaried and it dies.....
Ill see idf I cant try whst you guys are saying....thanks for all responses.
Re: 904 not going into 3rd all the time..... [Re: Hailtheleaf538] #1475174
07/28/13 03:27 PM
07/28/13 03:27 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if you cover the primaries and it does not die ...then you probably got a vacuum leak...
it should die if you cover the primaries..
Tony
70 AARCuda Vitamin C
Re: 904 not going into 3rd all the time..... [Re: 70AARcuda] #1475175
07/28/13 04:57 PM
07/28/13 04:57 PM
Tri Cities TN area
Tri Cities TN area
oh yah....was uh just seeingnif you guys were paying attention..
Just kidding... dont know where I got that from thanks for clearing me up......what youbsaid makes sense I was oit there and covered and said "yeah must be a vacuum leak, lol....
Thanks agsin brother, ill admit when I screw up, I know sone lack the humility to admir there isnt anything they dont know
Re: 904 not going into 3rd all the time..... [Re: Hailtheleaf538] #1475176
07/28/13 04:59 PM
07/28/13 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is the kickdown cable or linkage? Does the AFB you're using have the correct Mopar throttle lever extension?
Re: 904 not going into 3rd all the time..... [Re: John_Kunkel] #1475177
07/28/13 11:59 PM
07/28/13 11:59 PM
Tri Cities TN area
Tri Cities TN area
It is a linkage, brother....I said cable by mistake, meant linkage in the previous post as well. It came off of a Mopar, was gonna put it on the 318 poly I my '65 coronet I had in the mid 90's. found a cool Offy aluminum intake for it.......
I took a pic of the side of the AFB, and the side of the E brock. they both look different where the throttle cable and kickdown are supposed to be.
Im telling ya man, this thing was RIGGED. 3 Allen head bolts and 1 flat blade screwdriver bolt to mount the carb to the EDDY intake.
Best way I can describe it is it looks like a half-assed Mcgyver tried to rig everything on it.
Will see if I can post the pics of the brackets so you can see how different they are, in the mornig. Thanks guys.
Re: 904 not going into 3rd all the time..... [Re: Hailtheleaf538] #1475178
07/29/13 05:48 PM
07/29/13 05:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The generic GM throttle levers found on most aftermarket carbs doesn't work with factory Mopar linkage that's why you need the Mopar throttle lever extension. The AFB and Edelbrock need the part number 1481 shown below.
The archives has pics of various linkage configurations for reference.
http://www.moparts.org/Tech/Archive/auto/35.html
