Starter Motor Question #1474885
07/27/13 04:28 PM
07/27/13 04:28 PM
Badge Offline OP
Badge  Offline OP
I am trying to track down a no start problem. Can a mid 70's starter be jumped from small post to large to check if the starter motor is OK? I tried it and all I got was a spark when touching the two with a screwdriver.
Re: Starter Motor Question [Re: Badge] #1474886
07/27/13 05:02 PM
07/27/13 05:02 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
Re: Starter Motor Question [Re: maxwedge1] #1474887
07/27/13 06:16 PM
07/27/13 06:16 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
yes it can , if its only sparking , give the starter a few raps of a BFH and then see what happens . u have a good battery ?
Re: Starter Motor Question [Re: Badge] #1474888
07/27/13 07:27 PM
07/27/13 07:27 PM
If thae batt is up/cables cleaned which I'm sure they are since you've been on this, if you firmly touch the large/small terminals with a large screwdriver & it dont crank then yes the starter is the culprit. Just be careful not to touch the metal case. A nice display of sparks down there tells you that you have enough current to the starter & also have continuity on the ground side between the starter case back around to the batt neg post but the starter itself ain't functioning
Re: Starter Motor Question [Re: RapidRobert] #1474889
07/27/13 11:34 PM
07/27/13 11:34 PM
Badge Offline OP
Badge  Offline OP
Thanks for the info guys. I appreciate it. I will pull the starter and take it in for a rebuild.
