Not a newbie, new sign on and new cars, need trans help
#147471
11/08/08 07:00 PM
11/08/08 07:00 PM
Posts: 173 Tucson AZ
2cudabuck
Tucson AZ
Hey all hope everyone is well. I havent been on since I sold my 71 cuda, but I recently bought two cudas on ebay, I'm sure some of you saw the ad, a 70 and a 74 with a Hemi. Excited to be back in the fold with you all! I have been working on my damn trans all day in the 70. Fender tag says 904, and even if I disconnect all linkage and move the shift lever attached to trans, I only get 1st, 2nd, and drive, and when in park, the motor is still dragging against the trans. I drove the car all the way back from Albequerque and it was flawless. I have a long bumpy driveway at the ranch, and hit the headers a time or two on the way in. After that, it seemed like it didn't want to go into gear, so I replaced all the grommets in the linkage. Now it dispays the symptoms I described above. Any help, I have been under it all day, and am stumped! Thanks folks, look forward to contributing!!
Buck
Buck
67 273 Dart GT
69 RT 440 Charger (SWEET!)
70 318 Cuda
74 Cuda Packin a 426 roller Hemi
Re: Not a newbie, new sign on and new cars, need trans help
[Re: 2cudabuck]
#147472
11/09/08 05:50 PM
11/09/08 05:50 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does the car try to drive forward in Neutral? If it does and it binds up in Reverse the problem is in the rear clutch, it's not releasing.
This is usually caused by a failed Belleville spring in the clutch.
[Re: John_Kunkel]
#147473
11/09/08 05:59 PM
11/09/08 05:59 PM
2cudabuck
Tucson AZ
Yes it does!! Even when in park it seems to be dragging the motor. Sounds like you called it!! Is that a fix without pulling the trans?
Buck
67 273 Dart GT
70 318 Cuda
