Re: 800+ hp on e85
[Re: WHITEDART]
#1474543
07/26/13 09:39 PM
07/26/13 09:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I forget his name but he is on here... he built up a hemi that was 1050 hp and he was looking to make more.. that was on E-85.... what the heck are you saying about RPM... nope... well we will put it this way.. it works fine at 10,000 rpm ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: Quicktree]
#1474545
07/26/13 09:45 PM
07/26/13 09:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
not really sure about the rpm limit ![](/ubbthreads/images/graemlins/shruggy.gif) just a rumor I have heard. im shooting for 800 hp with this small block which will need some rpm behind it.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: 800+ hp on e85
[Re: WHITEDART]
#1474547
07/26/13 10:00 PM
07/26/13 10:00 PM
MR_P_BODY
what carb are you using MR P im looking at Quick fuel e85 1050 dominator
Same carb your looking at... you might want to go bigger.. as you said you need RPM and RPM takes air and fuel ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: MR_P_BODY]
#1474548
07/26/13 10:30 PM
07/26/13 10:30 PM
WHITEDART
bean town ....Ca
how close was that carb out the box..and did they build it for your combo
Re: 800+ hp on e85
[Re: WHITEDART]
#1474550
07/26/13 11:09 PM
07/26/13 11:09 PM
MR_P_BODY
They built it for my engine specs... was almost dead on.. I ended up jetting up 2 jet sizes ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: dusturbd340W5]
#1474552
07/26/13 11:44 PM
07/26/13 11:44 PM
MR_P_BODY
I believe that was DTHEMI maybe
Yes... thats who it was ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: dizuster]
#1474557
07/27/13 04:29 PM
07/27/13 04:29 PM
Posts: 2,578 sweden
1Fast340
sweden
It's most definitely NOT only 105 octane either... maybe on a test stand, but not in real world applications.
Almost as good as 116 from what I've seen with the turbo guys...
Won't make as much power as Q16 though. Lots of guys making over 800hp with it.
when it comes to the turboguys the E85 has the advantage of cooling stuff aswell and i bet it does that part better than 116 therefore makeing E85 a good fuel for forced induction ![](/ubbthreads/images/graemlins/thumbs.gif)
back to the topic of 800HP N/A on the E85,yes it works and is more than just tried. there is streetcars running in the 8īs on that stuff.
Re: 800+ hp on e85
[Re: dizuster]
#1474558
07/27/13 04:56 PM
07/27/13 04:56 PM
Quicktree
says 105 octane on the pump, but what do they know? ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: 800+ hp on e85
[Re: DakFink]
#1474562
07/28/13 08:41 AM
07/28/13 08:41 AM
MR_P_BODY
I've heard the octane can vary by season and location. But in General 110 is a safe number to assume. It can be higher and lower depending!!
NOT SURE HERE: but seems that E-85 vs Gasoline is kind of like Aluminum vs Iron heads. You can run Higher compression and get away with it and in many cases NEED to do so. That said if you can run 13:1 with 110-gasoline you may be able to run 14:1 compression with E-85.
I do know several accounts of people running 10.5:1 to 11.5:1 compression and 14-16 psi boost on E-85. Far a HP or ET's ?????
I've been running 14.1:1 on E-85 but like any of the compression things... its the cam that will determine cranking pressure... also the E-85 is 105 octane... 110 is E-98.... yes it will vary with season(winter is lower due to more gas in it) the northern states will see E-70 vs some of the southern states dont go that low ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: Quicktree]
#1474564
07/28/13 08:48 AM
07/28/13 08:48 AM
MR_P_BODY
I have bought 2 drums and both checked 90% down here we don't have winter blend from what I have seen.
Does yours always test that high... around here I havent seen more than 1% change on summer fuel ![](/ubbthreads/images/graemlins/wave.gif)
Re: 800+ hp on e85
[Re: MR_P_BODY]
#1474565
07/28/13 08:50 AM
07/28/13 08:50 AM
Quicktree
what I have tested has, bought from 2 different stations
Re: 800+ hp on e85
[Re: WHITEDART]
#1474568
07/28/13 03:13 PM
07/28/13 03:13 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Just to clarify my E85 is NOT 105 octane comment.
The process to test octane requires that the air charge be controlled so that all of the fuel being tested is done at a standard. The problem is that the E85 takes so much heat out of the air charge, that the test method requires them to CRANK the air heater to be able to get to the test temperature. In real life use, gas and E85 run at the same outside air temperature on any given day. So adding heat to the E85 air charge doesn't really represent real world conditions.
That being said, when they add significant additional heat into the E85 aircharge during the test, of course it won't have the same detonation resistance then gasoline does.
So yes... it might "test" 105 octane under the methods prescribed, however if you do true apples to apples air charge temp test the E85 would have a MUCH higher octane number.
Turbo guys or not... we all benefit from lower air temps, and that's why you can effectively run more compression.
Would any of you guys run a 14:1 motor on 105 octane gas? Probably not...
Re: 800+ hp on e85
[Re: WHITEDART]
#1474569
07/28/13 06:23 PM
07/28/13 06:23 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
My 505 C.I. low deck stroker with CNC ported Eddy RPM and a single plane Mopar M1 Dominator flanged intake made more HP with less torque using a Holley List # 9375 non HP 1050 CFM carb. using the local K&S 110 octane race gas, peak HP made was 681 and 682 HP was at 6200 and 6300 RPM on two different pulls, peak torque was 652 and 658 ft. lbs at 4800 and 4900 RPM on the same two pulls. The same motor using a Holley 1150 HP converted to E 85 ended up making a best (after many jet chnages) 676 HP at 6300 RPM and 666 Ft. Lbs at 4700 RPM ![](/ubbthreads/images/graemlins/shruggy.gif) This motor has 11.3 to 1 compression ratio with these heads, I was going to use a set of Indy 440-1 with smaller chambers to get 12.5 to 1 compression but those plans changed ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) IHTH ![](/ubbthreads/images/graemlins/thumbs.gif) BTW, I've seen our local pump E85 vary from E75 to E90 from winter mix to letting some of the summer mix set in a plstic jug for a year in the dyno room ![](/ubbthreads/images/graemlins/shruggy.gif) The last twenty gallons I bought this summer all tested to be dead nuts at E85% ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: 800+ hp on e85
[Re: WHITEDART]
#1474570
07/28/13 06:29 PM
07/28/13 06:29 PM
MR_P_BODY
I have heard that with alcohol the hotter the motor is the better it will run. is this true for e85. and how hot do you guy run this stuff dose that ice cold air and fuel charge wick all the heat out of the aluminum head.
That seems to be true.. I was gonna up my launch temps 20* to see if it helped... but some I have talked to said it would help... but it is a PITA to get it that warm ![](/ubbthreads/images/graemlins/wave.gif)
