torsion adjuster #1474318
07/26/13 03:55 AM
07/26/13 03:55 AM
san francisco
dawgfather Offline OP
san francisco
hi guys,
I just took my k member apart and cleaned it all up and painted POR-15 on it.. then I realized that it's a torsion bar adjuster.. the car was pretty rusted and when I took the k member apart the adjuster was not moving and did not think much of it. so the question is does the torsion bar adjuster move..? I am guessing that it does and if it does how much does it move? is it like flopping up and down move or kind of tight but it moves. sorry I am trying to explain it best as possible.. tried posting a picture but my computer was not able to.. will post picture soon
Re: torsion adjuster [Re: dawgfather] #1474319
07/26/13 07:39 AM
07/26/13 07:39 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes they move and IIRC they move fairly easy.Thats how the bar adjusts.Rocky
Chrysler Firepower
Re: torsion adjuster [Re: dawgfather] #1474320
07/26/13 09:01 AM
07/26/13 09:01 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Like Rocky said, that arm should literally flop around. Sounds like rust has seized it up.
Re: torsion adjuster [Re: Commando1] #1474321
07/26/13 10:47 AM
07/26/13 10:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Spray it down with some good penetrant.Them a few hits with a hammer should get it moving.Ive had one that didnt want to move and thats how I fixed it.Just hope the POR didnt get too far inside.Might take quite a bit of moving to get it to free up.I just bought some WD40 penetrant and it seems to work great.It was new so I figured Id try it.Rocky
Chrysler Firepower
Re: torsion adjuster [Re: therocks] #1474322
07/26/13 11:14 AM
07/26/13 11:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, it should rotate, but not be too sloppy. Probably needs a dip in a hot tank at this point. For reference on sloppy control arms and fix watch:
http://www.youtube.com/watch?v=Nwes-SP8u4w&feature=share&list=UUqvjc-8llEE-JKNFYw30-NQ
Re: torsion adjuster [Re: Jim_Lusk] #1474323
07/26/13 11:32 AM
07/26/13 11:32 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
great vid! wish I had watched this before I welded up the arms and powdercoated them
Re: torsion adjuster [Re: dangina] #1474324
07/26/13 11:51 AM
07/26/13 11:51 AM
san francisco
san francisco
thanks guys..!!! looks like i am screwed..and more time on working the control arm..!! *sigh* and also i did not realize that the bushing has 2 metal sleeves... i burnt out the bushing and when i tried to put in the new bushing then i notice that i did not do it right
Re: torsion adjuster [Re: dawgfather] #1474325
07/26/13 11:55 AM
07/26/13 11:55 AM
san francisco
san francisco
hey jim,
thanks for the video, very informational.. now if i go the lazy way i might cut the plate like you did and hopefully that would make it spring out alittle and weld it back.. what do you think..?
Re: torsion adjuster [Re: dawgfather] #1474326
07/26/13 01:26 PM
07/26/13 01:26 PM
san francisco
san francisco
ok got the adjuster moving.. but I need to see later in the day after spraying it with some penetrant. now to tackle the damn bushing..!!
