red header tubes #147407
11/08/08 05:50 PM
11/08/08 05:50 PM
Idaho
boomerodell Offline OP
Idaho
Finally got the engine in my challenger(new engine). And noticed that I had 3 header tubes glowing red. It was previously on a break in stand with some cheap 1 3/4 headers and mp elec. dist. Now its in the car with 2 super comps. and msd pro billet and 6al. When it was on the stand I never noticed any probablems with "glowing" header tubes. Is my timing off? Or just running lean? Its a 500ci with a 6bbl set up. This may be a stupid question but how can i adjust the mixture? The one screw i've found on the center carb doestn' do anything when turned.
Re: red header tubes [Re: boomerodell] #147408
11/08/08 06:16 PM
11/08/08 06:16 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
if those tubes are glowing at idle, I would say too lean. you will need to remove the front carb to get to where you can remove the float bowl on the center carb.
glowing like that I would jump 2 to maybe 4 jet sizes larger.
glowing while driving it could be a lean condition or to much timing.
more info is needed..
I am truckless..
Re: red header tubes [Re: boomerodell] #147409
11/08/08 06:16 PM
11/08/08 06:16 PM
yes check timing but LEAN like my oxy/acet torch when I add oxygen
Re: red header tubes [Re: boomerodell] #147410
11/08/08 06:25 PM
11/08/08 06:25 PM
Idaho
Idaho
I cant drive the car yet, no body panels. Just getting it together. Haha. But it does it when i hold it just past idle at a steady rpm. I can watch the tubes start to get red and when I let it idle it goes away after a few seconds. Thanks
Re: red header tubes [Re: boomerodell] #147411
11/08/08 06:29 PM
11/08/08 06:29 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Yep -- way too lean. Run it like that and you'll have over-heating probs too...ya need to richen her up.
Re: red header tubes [Re: boomerodell] #147412
11/08/08 06:32 PM
11/08/08 06:32 PM
(retarded) timing. See what your initial is & that it is advancing. See that the fuel level is at the bottom of the sight plug on the center carb.
Re: red header tubes [Re: boomerodell] #147413
11/08/08 06:39 PM
11/08/08 06:39 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Timings retarded or very rich mixture. Start with more timing advance,are you using vaccum advance? If not, you should.
Re: red header tubes [Re: boomerodell] #147414
11/08/08 07:29 PM
11/08/08 07:29 PM
Idaho
Idaho
Intial timing looks about 15 deg. advance. Is that to retarded or is it a fuel related?
Re: red header tubes [Re: boomerodell] #147415
11/08/08 07:38 PM
11/08/08 07:38 PM
your initial is fine. run it up a bit & see how much you have at the point where its glowing red. EDIT note the timing & the rpm. & if that's close to good then we can move on to mixture but with that being said you did change the DIST & with a six pack I'm sure that it wasn't changed.
Re: red header tubes [Re: RapidRobert] #147416
11/08/08 08:02 PM
11/08/08 08:02 PM
Idaho
Idaho
There is no change still 15 deg. I cant see the tach but i'm guessing about 1500 to 2000 is when they get red. What rpm should i see a change for the advance? The distributor has the heavy springs in it so i guess i should go lighter?
Re: red header tubes [Re: boomerodell] #147417
11/08/08 08:12 PM
11/08/08 08:12 PM
You run it up to ~ 1500-2000, what is the timing at that point. EDIT Am I reading this right that when you run it up it's still at 15?
Re: red header tubes [Re: RapidRobert] #147418
11/08/08 08:37 PM
11/08/08 08:37 PM
ont, canada
K
kenny b Offline
kenny b  Offline
K
ont, canada
I've seen this before when the head gasket was on backwards. Depending on which gaskets you used. Some have a front and rear to them.
Re: red header tubes [Re: RapidRobert] #147419
11/08/08 11:16 PM
11/08/08 11:16 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Fix the timing 1st. Should be lots more than 15 at 2000 RPM.
Re: red header tubes [Re: Lefty] #147420
11/08/08 11:58 PM
11/08/08 11:58 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Your distributor is not advancing.
Re: red header tubes [Re: goldmember] #147421
11/09/08 12:02 AM
11/09/08 12:02 AM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Very 'lean' mixture -- a rich mixture would cool your exhaust from unburnt fuel.
Re: red header tubes [Re: boomerodell] #147422
11/09/08 12:16 AM
11/09/08 12:16 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I built a 500 inch 440 and had to jet up the center carb on the out of box new repro holleys. due to same problem you are having. I also popped out the plugs on the end carbs to tweak the mixture screws just a hair.
Re: red header tubes [Re: Hotwheelsjr] #147423
11/09/08 12:17 AM
11/09/08 12:17 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Not the case. If a cylinder is very lean it will misfire creating less exhaust heat. Very rich mixture will still be burning as in goes out the port creating alot of heat. Advance the timing lean the rich cylinders and the problem is cured.
Re: red header tubes [Re: goldmember] #147424
11/09/08 12:18 AM
11/09/08 12:18 AM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
Re: red header tubes [Re: dm69charger] #147425
11/09/08 02:18 AM
11/09/08 02:18 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
but, don't forget, if it's not timing, lean enough to still burn without a misfire, will also burn hot.
so...could be lean, could be rich, could be timing.
**Photobucket sucks**
Re: red header tubes [Re: 70Cuda383] #147426
11/09/08 02:39 AM
11/09/08 02:39 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
