bell housing safety #1474100
07/25/13 03:30 PM
07/25/13 03:30 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
At what point should I consider up grading to a stronger bell housing? Is it the RPM or the torque that can cause an explosive malfunction of the clutch / pressure plate assy? Currently building a 512 w/ approx. 600 HP. Now a stock bell housing and 23 spline 833.
Re: bell housing safety [Re: BeeSuper] #1474101
07/25/13 03:55 PM
07/25/13 03:55 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
IMO any time you are going to beat on a stick car you need a blow-proof bellhousing. If you are going to have stick tires it is mandatory. I have seen quite a few cracked cast iron bellhousings removed from street cars with sticky tires and "spirited" driving techniques. A couple of them broke the block as well. Like so many other items on a good car it is cheap insurance.
Re: bell housing safety [Re: BeeSuper] #1474102
07/25/13 04:08 PM
07/25/13 04:08 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
ASAP!
Re: bell housing safety [Re: Jeremiah] #1474103
07/25/13 04:34 PM
07/25/13 04:34 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Thanks. Didn't think about the potential block damage.
Re: bell housing safety [Re: BeeSuper] #1474104
07/25/13 05:39 PM
07/25/13 05:39 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Also buy a Billet flywheel , 40yr old, heat cracked, cast wheels belong on trailer poodles .
Re: bell housing safety [Re: BeeSuper] #1474105
07/25/13 08:56 PM
07/25/13 08:56 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Also I'd upgrade to an 18 spline Hemi trans. I've seen 23 spline input shafts with the splines realigned by the clutch plate.
