Page 3 of 4 1 2 3 4
Re: does buildsheet show if a 22" rad car gets a shroud [Re: scatcity] #1474043
07/31/13 12:29 AM
07/31/13 12:29 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i find it incredibly hard to believe every HP car in 70 with a 22" Rad came with a shroud from the various assembly lines. Regardless of what the FSM dictates. There's the FSM and then the real world..
my 3 70 V codes had 22" rads and NO SHROUDS..
Re: does buildsheet show if a 22" rad car gets a shroud [Re: Mike Mancini] #1474044
08/01/13 12:06 PM
08/01/13 12:06 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
70 E-Body 440/440-6 Automatics without an axle package got a 22" rad with shroud. Had a few originals. I will guess 383 cars as well.
Agree that the broadcast sheet does not have a space for a shroud.
The '71 'Cuda 440-6 promo cars....mine has a 22" rad.....Mike - I am assuming the one you did had a 22" as well?
Re: does buildsheet show if a 22" rad car gets a shroud [Re: Mike Mancini] #1474045
08/01/13 02:13 PM
08/01/13 02:13 PM
What does early and/or promo cars have to do with the subject?
Absolutely nothing...considering all the challenger promo cars were 440-6, 4-SPEED, 26" RADIATOR cars!
FJ5 Fish,
Mike said that ALL challenger promo cars had 26" radiators
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ph23vo] #1474046
08/01/13 02:17 PM
08/01/13 02:17 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& how would you know this?
There has been NO evidence provided that a HP engined 22" radiatored A, B, C, E - body car did NOT have a shroud.
FYI:
The '70 Challenger R/T convertible 440+6 "US spec. promos" were 4-spd, 4.10s, 26" radiator & shroud.
The '71 'Cuda hardtop 440+6 "US spec. promos" were automatic, 3.23s, 22" radiator & shroud.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ] #1474047
08/01/13 02:18 PM
08/01/13 02:18 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I know - just making a point/asking a question on the 71 Promo 'Cuda's....I have one and I am pretty sure he restored one. Just wandering off-topic a step or 2.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ] #1474048
08/01/13 11:35 PM
08/01/13 11:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
FJ5 Fish,
For whatever it may be worth, not all 1970 promotional Challengers were big block cars, I know of two 318 promo cars with 22" radiators - so far.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: Alaskan_TA] #1474049
08/02/13 09:02 AM
08/02/13 09:02 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I have a few 70 e bodies with the 960 rad and they all have a shroud, 383 and 440.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: Alaskan_TA] #1474050
08/02/13 10:14 AM
08/02/13 10:14 AM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
Barry
318 cars had 19" radiators, or 26" with a/c
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ph23vo] #1474051
08/05/13 12:18 AM
08/05/13 12:18 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have always wondered why the side brackets on a C Body 22" rad are so different than the ones on A, B, and E Body rads. They do not even have provision for the small brackets that are all on A,B, and E, body 22" rads that are used to help attach the shroud to the rad. So, I would think that Dan is correct when he says that none of his 22" rad cars came with shrouds, there is no way to attach them to the rad. All 70 and 71 440+6 C Body cars came only with 22" rads, the other motors on a C body that used 22" rads would not use a shroud either. I bet there is no a 22" shroud listed in the parts book for any C Body.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: 6bblgt] #1474052
08/05/13 12:22 AM
08/05/13 12:22 AM
m46rat Offline
m46rat  Offline
Dwight, what evidence do you have that the above mentioned non-HP cars would/should receive a fan shroud?
Dan: The only thing I can tell you that backs up my claim, is that there are marks on the original rad small side brackets indicating that a shroud was attached.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: m46rat] #1474053
08/05/13 02:29 PM
08/05/13 02:29 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1970 C-BODY 22" radiator SHROUDS
2998329 - /6
2998330 - big block
Re: does buildsheet show if a 22" rad car gets a shroud [Re: m46rat] #1474054
08/05/13 10:26 PM
08/05/13 10:26 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
none of the 22 radiators have any provision for a shroud.. so not sure how one would be attached.. the 330 shroud i had mounted like any other shroud.. parts book list no shroud mounting brackets or hardware either.. very odd for sure.. never seen a 330 shroud still in a car
..they exist but what did they come in i sure can't say...
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ph23vo] #1474055
08/07/13 01:22 PM
08/07/13 01:22 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
here's a LOW MILE survivor 440 22" rad C body..see for yourselves..
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ph23vo] #1474056
08/07/13 06:08 PM
08/07/13 06:08 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
sure there is,zoom in on picture you can see the 2 or 3 open holes where nutserts go to mount the shroud brackets
Re: does buildsheet show if a 22" rad car gets a shroud [Re: whomper1] #1474057
08/07/13 07:27 PM
08/07/13 07:27 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
whachou' smokin willis?... there is no holes for a shroud anywhere on that rad.. LOL
Re: does buildsheet show if a 22" rad car gets a shroud [Re: ph23vo] #1474058
08/07/13 09:57 PM
08/07/13 09:57 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
not the same stuff you are
relook at your pic
Re: does buildsheet show if a 22" rad car gets a shroud [Re: whomper1] #1474059
08/07/13 11:13 PM
08/07/13 11:13 PM
minnesota
billyfury Offline
billyfury  Offline
minnesota
not sure those holes were designed to insert anything into.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: whomper1] #1474060
08/08/13 12:05 AM
08/08/13 12:05 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
relook at your pic
LOL THOSE AREN'T SHROUD HOLES... never seen any mopar car with anything in those holes on the side of the rad strap.. different manufacturers of rad possibly used these straps on many cars back then.. keep trying.. looked at all 3 of my 440-6 rads and none have any sign of anything ever being in these holes.. maybe some car used them for a shroud bracket but which one?
Re: does buildsheet show if a 22" rad car gets a shroud [Re: whomper1] #1474061
08/08/13 02:07 AM
08/08/13 02:07 AM
m46rat Offline
m46rat  Offline
relook at your pic
Hmmm, please post your survivor pics of the 22" rad that you have with the untouched 440 and original 2998 330 shroud attached to it. Make sure to take a lot of close ups for all of us doubters.
Re: does buildsheet show if a 22" rad car gets a shroud [Re: m46rat] #1474062
08/08/13 09:36 AM
08/08/13 09:36 AM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Here is a photo pf the 22" radiator shroud bracket that attaches to the side of the radiator. Ignore the philips head attaching screws. That's what happens when your kids do stuff when you are out of town.
Larry
Page 3 of 4 1 2 3 4
