Re: Chassis certification tag lesson needed
[Re: 71nonRT340shaker]
#1473975
07/25/13 12:11 PM
07/25/13 12:11 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
NHRA chassis cert will be a decal on the passenger's side of the main hoop...should be able to see it through the passenger's door window. I believe IHRA is done the same way.
Sounds like you have a tag on the cage from whoever built the car.
#1473978
07/25/13 01:19 PM
07/25/13 01:19 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you ever want it done Pittsburgh Raceway Park brings in a IHRA inspector every Spring before the season starts. They always post the date and times on their website so people can call to set up appointments.
[Re: Moparpoor]
#1473980
07/25/13 07:45 PM
07/25/13 07:45 PM
Posts: 116 Pa
71nonRT340shaker
Pa
It is a chassis builders serial number! It is required by SFI. Any chassis shop is required to place a serial number on the car and retain all documentation on the chassis!
Is there a be all end all list of these numbers? Does one single number stay with the shop or do they apply a number to each build (chassis) in chronological order from whatever car is being built and gets it certified?
To sum that up, does the number belong to a specific shop or that single car?
#1473983
07/26/13 05:18 PM
07/26/13 05:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you had a little of the history of the car you can back track it and ask builders in that area if they know that serial number or know whos number it is.. even pics of the chassis helps.. some chassis builders do things a certain way
