Re: hemi cuda power brake install
[Re: DAYCLONA]
#147381
11/09/08 10:11 AM
11/09/08 10:11 AM
Posts: 10,756 North Dakota
6PakBee
North Dakota
Does the use of the manual brake firewall plate apply to the power brake 'B' body Hemi cars also?
[Re: 6PakBee]
#147382
11/09/08 11:28 AM
11/09/08 11:28 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes it dose Roger,....66-70, B Bodies you have to use the manual master cylinder plate, as the pedal pushrod hole in the manual plate is lower than the power booster plate (standard power booster application, where the booster is mounted directly on the firewall, no offset)
71 B body also need to use the manual master plate as well if using a "HEMI" booster......the 71 B body plate is the same a E body
The reason being, as I stated above for using the manual master cyl plate, is the "HEMI" booster set up, the main push rod bolts directly to the pedal,....where as in NON-HEMI applications of power boosters, there an intermediate linkage bellcrank assy located on the pedal bracket assy inside the car to raise the linkage, to center it on the power booster, where the booster would be bolted directly to the firewall, because of this a seperate "power" plate was made,......The HEMI bracket set up raises the booster higher and approx 3 1/2 inches away from the firewall, thus you need to use a "manual" master cyl reinforcement plate
[Re: 6PakBee]
#147383
11/09/08 11:31 AM
11/09/08 11:31 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#147384
11/09/08 11:32 AM
11/09/08 11:32 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 70cudaMD]
#147385
11/09/08 11:33 AM
11/09/08 11:33 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 6PakBee]
#147386
11/09/08 11:35 AM
11/09/08 11:35 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 6PakBee]
#147387
11/09/08 11:37 AM
11/09/08 11:37 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 6PakBee]
#147388
11/09/08 11:39 AM
11/09/08 11:39 AM
Posts: 18,157 Mass
DAYCLONA
Mass
