Re: Track rules - could hurt car count
[Re: 69CHARGERMD]
#1473705
07/24/13 11:50 PM
07/24/13 11:50 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Even though most tracks require diapers at 9.99 like NHRA rules state. NHRA took it further and extended it to the Super Street class in 2009. I last raced that class in 2008, the diaper rule was the last straw.
Everyone always says, "If you can't afford to adhere to this rule, or that rule, or this price increase or that price increase, maybe you shouldn't be racing at this level"!
Then when you quit, they all call up and ask, "What the Hell, you don't like us anymore?"
In 2006 the total amount of cars competing in NHRA Super Street topped out at 1,019 nation wide. As of right now the participation count for 2013 is 637!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: slantzilla]
#1473708
07/25/13 07:56 AM
07/25/13 07:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
While I can appreciate a car being safe but the rules are driving ALOT of guys out of racing... start adding up the price of ALL the items to run a 9.80 pass.. by the time you put a cage in and get a license and the safety gear its not worth the .2 in NHRA.. I just used 9.80 as a number but IHRA is better on this stuff... I cant get a license in NHRA but I am legal in IHRA to run 8.50... sure wish the IHRA would have more tracks than they do now
[Re: MRMOPAR622]
#1473713
07/25/13 10:29 AM
07/25/13 10:29 AM
Posts: 2,177 ill
dennismopar73
ill
I for one don't think the rules for any of the speeds/et are in anyway out of hand,, i fact those are just basic min , street cars only require a helmet, seat belt! sprotsman not much more depending on slicks /driveshaft loop, pro, still the same , So all the rules are just basic rules until you get to 10.99 or faster, then still very basic unless you have a full cage, then it is realated to better belts and some padding around your head! WOW 19 bucks that break ya! You the racer determans what and how fast your car goes not any racing body! When it comes to saftey seams that is the very first place everyone wants to cut out! hard to understand that stupid way of thinking IF SOMETHING SHOULD HAPPEN,, you ,,your wie , kids will be happy you had it and the track required you to have it on! I have zero tolerance for those who decide that safety should be last,, but yet build a first class race car spare no exspence on motor car , bt stupid on saftey of it for other and spectators a like , This topic is a no brainer , unless you have no brain,, by the looks of the replys some lack!
[Re: J_BODY]
#1473715
07/25/13 11:01 AM
07/25/13 11:01 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
When the diaper rules started to come out I reacted like everyone else. I hate more rules, the additional cost, more stuff on the car, in my way when I want to work on it. Then my knowledge base was expanded.
The purpose of a diaper is to make you look smart. If you ever blow up an engine (I know, you think that will never happen to you) it will most likely blow at maximum load. Right before the finish line. You are going at near maximum speed. Things can get real ugly, real fast. If oil/water gets on your tires and you crash, you will find out why a diaper makes you look smart.
2011 Drag Pak Challenger
[Re: Dragula]
#1473720
07/25/13 03:43 PM
07/25/13 03:43 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
They implemented a similar rule at our track. The rule was any vehicle running faster that 12.99 required a diaper or a pan. You could choose not run one but if you oiled the track you would be subjected to a $500.00 fine. However, if you have a diaper and hurt the engine but did not oil the track the ownership would give the racer $250.00 if the diaper was damaged There was a huge uproar initially and I was in total agreement. Not necessary about the rule because I am an advocate of diapers or lower engine containment devices for the safety of it. However, in a day and age when we are losing racers at a rapid rate I thought this was a step in the wrong direction if we are trying to attract new people to participate especially in the slower classes.
I guess the part that I have an issue with is this. The sanctioning body's, namely NHRA are putting their foot down with regards to engine diapers. The main idea is to stop oil and debris from getting under the tires in the case of an incident. (Actually I don't think that is the real reason. I know at our track it was all about the cost to clean up!) Then I suggest that they outlaw all dragster headers that point straight at the middle of the rear tire. We had a big buck race here on the weekend and there must have been 60 dragsters all with the same headers. If a motor drops a valve and the diaper is required I will guarantee there is sharp stuff coming out of the exhaust just dying to cut a tire.
My guess is NHRA does not want to pi$$ off the big money guys with there fancy stacker that has 6 dragsters in it, but I don't think they are overly concerned about the regular guy that is scraping every penny together to go to the next race.
Just my 2 cents
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
